Rocker arm fell out
Old Apr 14, 2010 | 08:41 AM
Ev0six's Avatar
Rocker arm fell out
The exhaust rocker arm today came off on cylinder #3. I was just pulling out into the main street in my neighborhood and felt the loss in power. I drove it back and pulled the spark plugs thinking maybe it was bad plugs. It wasn't so i did a compression test. Turned out to be 0 in #3 and 185 in the rest. Next was removing the valve cover and i find a rocker arm lying at the bottom. Looks like the valve tip is about 3mm shorter than its other paired exhaust valve. So i'm guessing that its bent. The head was rebuilt a year ago (supertech valves/springs/guides). I put about 2000 miles on it since the rebuild. Any idea's on what would make this happen?
Old Apr 14, 2010 | 08:44 AM
Evo9"Miss Rose"'s Avatar
did you change your timing belt during your head build?!?!!??!
Old Apr 14, 2010 | 08:49 AM
Ev0six's Avatar
Yes i did. I had the whole motor out during the rebuild for the bottom end. I used new bearings and PE kevlar timing belt. I thought it might have been a lifter problems but it was still "firm" and i bled and cleaned it out. If the timing belt jumped, i assumed that it would have taken more of the rockers out. Even the slightest hint of binding during cranking would have been sure indication of a jumped belt but it didn't and compression was good for the rest.
Old Apr 14, 2010 | 08:50 AM
scheides's Avatar
EvoM Moderator
What springs are in the head? They can wear out.
Old Apr 14, 2010 | 09:11 AM
Ev0six's Avatar
Supertech springs, supertech valves, supertech guides
Old Apr 14, 2010 | 09:22 AM
scheides's Avatar
EvoM Moderator
And what cams? Those springs might be your problem. I have no direct experience with them, only heard rumors of them fatiguing and causing float.
Old Apr 14, 2010 | 09:40 AM
hotrod2448's Avatar
I was going to suggest a collapsed lifter because it sounds like you had just started the car and weren't winding out where float should be an issue but, it sounds like you've already looked at that.
Old Apr 14, 2010 | 09:42 AM
Ev0six's Avatar
hks 264/272
Old Apr 24, 2010 | 08:14 PM
rd122481's Avatar
So...what ever happened?
Old Oct 7, 2010 | 05:27 PM
NOMIEZVR4's Avatar
just happened to me, any reason?
Old Oct 7, 2010 | 05:47 PM
VRSF Tiago's Avatar
What springs/cams are you running?
Hartless93
34
Dec 1, 2016 07:20 PM
EVO 4 life
Jun 21, 2016 08:52 PM
Tw3NTy0n3
May 21, 2016 11:24 PM
RyanD3
Mar 8, 2016 02:37 PM
althemean
Apr 18, 2006 08:20 AM
