Trick to oil pump screw?
Old Apr 17, 2010 | 01:22 PM
icantdrive75's Avatar
Is this thing loctited(is that the proper adjective?) or what? I almost stripped it with a regular screwdriver so I bought an impact, and I still can't get it to budge.
WTF m8.
Old Apr 20, 2010 | 09:09 PM
WHTEVO's Avatar
The hex bolt in the oil filter housing? You need to heat it up a little to get it to break loose. Good luck.
Aaron
Old Apr 20, 2010 | 09:16 PM
Aaron
No sir, the set screw on the oil pump housing. It's an actual phillips head screw. I got an impact screwdriver, but the instructions were too vauge A friend got home that had used one before and it came right off. Turns out I was just hammering it, not actually turning it either way.
MalibuJack
May 25, 2017 06:46 PM
STUNNA#1
Aug 14, 2016 05:25 AM
EvoOtto
Oct 29, 2015 07:13 PM
camoner
16
May 19, 2014 08:07 PM
reliablefr
18
Aug 30, 2012 11:46 PM
