cam sensor
Old Apr 22, 2010 | 09:09 PM
style619s's Avatar
cam sensor
does anyone know how to check cam sensor?? im having problems with starting my car.. it cranks but seems like no spark i mean i have to pump the gas like crazy and then it starts its missing and idle rough and drops... new plugs, coils, and wires still no luck..
mods are
exhaust mani
works reflash ecu
3inch exhaust (cat delete)
hard piping
front mount
hks bov( not recirculating )
works cams 269
works TB
clutch
AEM air intake
funny thing is car is not even showing any codes and when i take off it makes some ticking noise but at about 15mph it goes away ( basically at higher RPM)
Old Apr 23, 2010 | 09:49 AM
style619s's Avatar
any ideas???
Old Apr 23, 2010 | 10:45 AM
style619s's Avatar
bump...
Old Apr 23, 2010 | 02:43 PM
style619s's Avatar
bump anyone ?
Old Apr 24, 2010 | 05:08 AM
style619s's Avatar
bump ...
style619s's Avatar
i mean someone gotta had the same problem before ..
Old Apr 24, 2010 | 05:10 AM
Sully 18's Avatar
check to see if ur getting 5 volts the the connector 1st off
Old Apr 24, 2010 | 05:12 AM
Sully 18's Avatar
timing could of jumped as well... and what did u set the gap in the plugs too
Old Apr 24, 2010 | 04:46 PM
style619s's Avatar
ok thanks man
i check the sensor and it was showing 4.5 volts ..is that normal??
After checking it . i started the car and it was fine... i let it warm up and took it around the block and came back. it started acting up again..
i set the plugs to .25 .... i got a recirculating kit coming for my bov and new plugs (one step colder)
also i forgot to mention that all this started after i took the battery out to get it tested and put it back in
Old Apr 24, 2010 | 05:40 PM
Jspec EVO VIII's Avatar
You getting any missfire while driving as well?
Old Apr 24, 2010 | 08:25 PM
style619s's Avatar
only at lower rpm 1k-2.5k and drivers just fine... when i come to stop thats when it starts idling rough and dies
Old Apr 25, 2010 | 06:47 AM
Sully 18's Avatar
how many miles on the car?... disconnect maf and see if it runs better
Old Apr 25, 2010 | 11:20 AM
style619s's Avatar
I'm about to hit 30k miles and ill try that once I get home from work. And report back asap
Old Apr 26, 2010 | 03:43 PM
style619s's Avatar
ok i disconnected maf sensor and car would start and die and threw CEL (maf)
but i did take my plugs and still had them connected to coils and had my friend crank the car and not all of them would spark!?!?!?
so im guessing im not getting a spark
any ideas?
Old Apr 26, 2010 | 03:44 PM
style619s's Avatar
oh btw and i did put a new cam sensor and reset the ECU after and didnt change anything
