Ticking sound from comming the head
Old May 12, 2010 | 11:14 AM
  #46
turbotalawd's Avatar
No way theres a warranty with it being a theft recovery.
Old May 12, 2010 | 06:18 PM
  #47
domantas's Avatar
its still a clean title car
Old May 12, 2010 | 07:08 PM
  #48
domantas's Avatar
I already have the new rods, main and rod bearings, crank, oil cooler. What else I might need to replace?
Do I really need to get the new head gasket, head studs, main studs and pistons when rebuilding block from spun bearing?
Old May 12, 2010 | 07:16 PM
  #49
domantas's Avatar
what do you mean? I have a spun bearing and im trying to get it running again. No fancy build here ^^^
Old May 12, 2010 | 07:28 PM
  #50
JFuego777's Avatar
You will definitely need a head gasket since your head has to come off to get your pistons/rods out/in and to have the block properly cleaned. I personally would get pistons while I had it apart, that is optional though, as long as the stockers are in good shape
Old May 13, 2010 | 11:01 AM
  #51
domantas's Avatar
ok, here is what I got... I just bought a deal on brand new evo 8 OEM rods, pistons, rings, main and rod bearings. I just talked with my shop and they told me that evo 8 pistons have different compression than evo 9. Would that be a problem to run them on evo 9 block? He also told me that rods and bearings are all same in 8's and 9's. Anyone can confirm this?
Also, do I need a new oil pump, or cleaning it would do the trick?
Old May 13, 2010 | 11:22 AM
  #52
VETTE_50_TH's Avatar
Does it have oil??
Old May 13, 2010 | 11:24 AM
  #53
20gmr's Avatar
anyone else notice thats not a IX motor?? that looks like an ebay *jdm8 evo 7 engine*
Old May 13, 2010 | 11:53 AM
  #54
johno's Avatar
Well my dad does machining at our house. If you got all the parts you might as well get an oil pump and water pump its cheap insurance of keeping your motor going. I highly recommend an oil pump at least. As far as the pistons being different i dont know it cant be that much of a change. 8 and 9 motor are pretty much the same. Also dont delete the oil cooler either make sure you replace that also and you should be good to go. As far as your dif thats prolly pretty screwed up running dry. I had the same thing happen to my eclipse tranny but i filled it up with oil and it works perfectly fine so idk
Old May 13, 2010 | 11:55 AM
  #55
domantas's Avatar
Originally Posted by 20gmr
anyone else notice thats not a ix motor?? That looks like an ebay *jdm8 evo 7 engine*
oh, the first post... lol its not mines, its just for a reference. It spun a rod bearing. At firs it sounded like the lifter tick, it was quiet and if you experiance some tice, take ur ol pan out to see ifd ur bearings are not spun. Hard learning experiance for me....
Old May 13, 2010 | 07:07 PM
  #56
But the dealer still knows its a theft recovery.
Old May 13, 2010 | 08:19 PM
  #57
domantas's Avatar
its clear from theft in carfax, has undercarriage damage dough...
Old May 13, 2010 | 10:05 PM
  #58
ch53avitech's Avatar
How common is this knocking problem? I have ticking noise coming from my head but it sound more like the lifters. This thread scared me because I have a brand new BR motor.
Old May 14, 2010 | 09:59 AM
  #59
domantas's Avatar
I have most of the parts for the block, what I should consider changing engine head wise for the engine with a spun bearing? Im having my block and head cleaned and assembled by apm racing shop in Chicago, but I want to provide them with all parts needed. Could my cams be potentially shot?
Old May 14, 2010 | 10:29 AM
  #60
cssaddictm4's Avatar
It is possible to have damage to the cam lobes, albiet unlikely.
