Whats wrong with my tranny?
Old Apr 29, 2010 | 02:41 PM
nikkadanny's Avatar
Here's my problem, last week i was driving around, i decided to go thru the gears 1st to 4th. I let off, drive normal and then my tranny gets this weird vibration right about 3k. No matter gear i am in it does it, no whine or anything. But it is hard to get into gear 1st to 5th, and this is driving normal. I check the peep hole at the bottom of the tranny and check the pressure plate no wobbling or anything. I called kevind and he said i might have broken a spring on my clutch disc, i have a act 6 puck sprung. i checked everything around it and nothing is loose.
any input helps
thanks.
Old Apr 29, 2010 | 02:42 PM
Kracka's Avatar
I'm with Kevin, sounds like a clutch disc issue.
