HP Limit on Catalytic Converters?
Old Apr 30, 2010 | 04:17 AM
AlligatorMan's Avatar
I'm having a hard time getting over 350whp with a 3" magnaflow ceramic cat on 94 pump and S256 turbo. Motor knocks once I get in the upper RPM which leads me to believe that the flow is being restricted/high egt (no gauge just a guess). It didn't do this before with just a straight pipe.
Is this typical or should I re-visit the tune with less timing?
A/F at 11.4:1.
Cheers,
Nate
Old Apr 30, 2010 | 06:47 AM
zeus1's Avatar
sounds like you need to revisit the tune. cats restrict flow quite a bit at least when i switched from a cat to test pipe it really opened up the car
