Need HELP!!!!
Old Apr 30, 2010 | 08:40 AM
Fp3052's Avatar
Need HELP!!!!
I was at the the track and when i launched my car I heard a pop, the car still took off, once I was done with the run I noticed when I turned the car would make a popping noise and it only did that then I would turn. Then next day I was driving and decided to floor it and the car started going side ways :0 So I get home lift the car and got all four wheels of the ground, put it in gear and to my surprise only the back wheels were spinning! What could be wrong with the car could it be the trans case?
Old Apr 30, 2010 | 08:45 AM
Smike's Avatar
Check front axles too.
Old Apr 30, 2010 | 08:56 AM
thedru13's Avatar
x2 on the front axles. When this happened on My Girls DSM Spider diff was in peices.. custom RWD conversion.. Are you leaking fluid at all?
Old Apr 30, 2010 | 08:59 AM
Fp3052's Avatar
I did the passenger side axle band came off and the grease all came out, took it to a axle shop they looked at it and said it was fine they re greased it put another band on I reinstalled it and still the same, I'm gonna put some trans fluid and drive it to see if it still makes the popping noise
Old Apr 30, 2010 | 09:03 AM
thedru13's Avatar
I would drain both the Tcase and Trans. See if there is alot of metal in there before I would drive it much more.
Old Apr 30, 2010 | 09:30 AM
Fp3052's Avatar
No it's not leaking any fluid and I'll check to see if any metal shavings are in the fluid when I drain both
Old Apr 30, 2010 | 10:07 AM
turbo speedy's Avatar
transfercase
