aem ems/ buschur cop cdi/ no spark
Check your ignition fuse #1 under the dash! I am almost certain it has blown. I had purchased an AMS CDI COP with M&W Pro 12 and I kept blowing the fuse so AMS told me to put my stock ignition back on and it solved it. I am not sure what causes the problem but it is something in the CDI box I believe. I hope I have helped with your situation and good luck!
And odds are if your cam and crank sensors have been replaced they are more than likely good. The crank sensor does have the control to cut off power to spark and fuel but it will usually start to run a little weird at first or even have starting issues. again best of luck.
If the fuse under the dash would have one out, would I be able to get up to 31 psi @ 647 on a mustang dyno? I would of thought it would of quit before that. Anyways I emailed David for some pointers, on the settings it should be on aem ems 2.
hey brO just saw this Im in the same situation... once i got my buddy to come by and swap ignition back to stock my car finally started up. it has to be something with the box, in my case the wiring needs to get checked out. Good luck bro
evotris
Sep 15, 2016 03:19 PM
WTB[Northeast]: Buschur Cdi Cop
yellowevo82
Sep 14, 2015 09:13 AM
WTT[Northeast]: Spoolin up COP evo 8 BNIB
03Roush2
Aug 18, 2015 08:42 PM
