transmission oil
Old May 5, 2010 | 08:28 AM
rartist's Avatar
transmission oil
I've been noticing over the past week or three that my 03 is getting harder to shift. It's been a good while since I've done an trany oil change so I checked locally to see if my auto part store had the stuff to do it. They have a synthetic gear oil (I don't know the brand) that is 70w-90, is it ok to use that or should I order it online and wait?
Old May 5, 2010 | 08:34 AM
Smike's Avatar
Amsoil MTG
Old May 5, 2010 | 08:39 AM
glgz's Avatar
I use Pennzoil Sycromesh. I have had in mine for almost 30k with no problems. Before when I had the factory fill I had the fifth gear grind at high rpms and it was hard to shift into 1st from 2nd when the trans was cold. I don't track my car or anything but do run hard now and then. You can find it at Advance Autoparts if they are around you.
Old May 5, 2010 | 08:50 AM
rcheung's Avatar
You dont want to use a brand that you are not sure of in any evo drivetrain component. People have had issues with tcase/tranny rear diff due to incorrect fluid. You can search and see what brands are proven to be ok.
Old May 5, 2010 | 07:07 PM
rartist's Avatar
I ordered some new trany oil for it, but the problem is getting worse rather quickly. The shifter is reluctant to go into gear hot or cold, and I almost can't get it into reverse at all. With the car sitting on a level surface it will roll slightly forward or backward when I push the shifter into forward or reverse with the clutch in. There's no grinding noise, tho there is a very small sound as I let out the clutch (a faint rattle and a small squeek); it is an 03 with 116k miles.
Is this the old oil telling me to change it or is it a real mechanical problem? The car power off will happily go into any gear, start the motor and 1-4 are usually stiff (but not always) and reverse is very hard.
Jovan Caro
Feb 8, 2017 08:12 PM
coryo93
Dec 7, 2015 06:42 PM
BoostedFODO
Oct 1, 2015 02:26 PM
BleedTheSky
Jul 16, 2010 08:40 AM
DGS
25
Nov 24, 2004 02:56 PM
