Finally Found the Leak
Old May 6, 2010 | 07:04 AM
ravnos04's Avatar
Hey All,
Finally, with the help and tools of my tuner, I finally found where the boost/vaccuum leak is coming from. When we put only 10psi into the system, there was a leak coming from the TB. I think it is the seals, but I am not sure. The leak was coming from around the throttle lever, and when I turned the lever, the leak sort of dialed down a little. Is that the seals?
Any help would be appreciated, thanks.
P.S. We did a boost leak...just in case anyone was going to ask. No other leaks we found.
Old May 6, 2010 | 07:07 AM
mdsevo06's Avatar
That's the TB Seals, a Milspec 65mm will solve that.
Old May 6, 2010 | 07:25 AM
ravnos04's Avatar
So your saying get the MIL.SPEC 65mm TB with seals?
Old May 6, 2010 | 07:45 AM
chin0's Avatar
^^^yes.
Old May 6, 2010 | 09:10 AM
Fast_Freddie's Avatar
Veteran: Navy
Or just get the Mil.Spec throttle body shaft seals...
Old May 6, 2010 | 09:34 AM
TeStUdO's Avatar
Yeah, and save yourself about $250.
