crank sensor ...
Old May 9, 2010 | 02:15 PM
style619s's Avatar
crank sensor ...
hey guys!
today i started on replacing my crank sensor and got in to couple of problems.. i already got the lover cover off and looking at the crank sensor.. and kind of confused on how to take it out because the cable goes behind the power steering pump and all that ...
so does anyone know a good guide on how to replace crank sensor??
Old May 9, 2010 | 02:21 PM
izabran's Avatar
you have to putt the power steering pump off... it's kind of annoying but it's pretty simple...
just know when your pulling it oout if your timing belt is still on... your going to have to move it a bit with a screw driver because the snsor won't make it out with the belt there... nothing serious you'll notice what i'm talking about when you do it...
Old May 9, 2010 | 02:31 PM
style619s's Avatar
sweet man yeah i was looking at the power steering pump and it looked like it was ganna be a pain in the *** ..and my timing belt is still on good think you said you can move it because i was thinking about taking it off and im sure it would turn into a nightmare lol
Old May 9, 2010 | 02:32 PM
evo8nfs's Avatar
the sensor can clear the timing belt you just have to be a lil creative and you dont have to remove the power sterring pump. at least i didnt have to with the way i ran mine stuff.. if you look at the way the sensor is run you wont have to remove anything.. look a lil bit harer my friend its actually a pretty easy install
Old May 9, 2010 | 02:43 PM
izabran's Avatar
ummm.... how did you get it out with out REMOVING the power steering pump... only wya i saw was cut the old crank senor... and re-route the new one?
Old May 9, 2010 | 02:44 PM
style619s's Avatar
yeah the cable goes behind the bracket that holds the power steering pump up and it wont clear the clip if i pull it out from down there... but if i got some pics of how you ran your.. it ll be nice
Old Jul 25, 2010 | 05:31 PM
ezzey's Avatar
im in the process of changing mine... so far its a pita, trying to do it without touching the steering pump.
