Need help identifying some things..
Old May 12, 2010 | 06:38 PM
awd2gen's Avatar
1. There is a single wire running off the power steering pump...what is its purpose?
2. Wish i could get a pic and i can tomorrow if its needed but on the water neck there is a metal male connector...what is it for?
Old May 12, 2010 | 07:30 PM
1badgsex's Avatar
yeah i also need to know where to get one i ripped mine out too by accident and now that little spiky metal thingy is all bent up so i just want to get a new one
Old May 12, 2010 | 09:41 PM
awd2gen's Avatar
which one did you rip out by accident? I ripped the one thats on the power steering pump out by accident.
Old May 13, 2010 | 07:49 AM
barneyb's Avatar
The wire to the PS pump tells the ECU to bump the idle so that you don't kill the engine while parallel parking.
Old May 13, 2010 | 08:03 AM
awd2gen's Avatar
damn i guess ill figure out a way to fix that one..
now for #2
Old May 13, 2010 | 10:27 PM
awd2gen's Avatar
BUMP for needing to know what #2 is.
#1 has been fixed.
Old May 14, 2010 | 02:06 PM
awd2gen's Avatar
no one knows???
Old May 14, 2010 | 02:12 PM
evozmarine's Avatar
on what water neck?
Old May 14, 2010 | 03:03 PM
awd2gen's Avatar
ok i guess a better way of describing it..its on the front of the thermostat housing right beside the stock turbo coolant line.
Old May 14, 2010 | 03:05 PM
JDriver47130's Avatar
It is probably a water temp sensor...
Old May 14, 2010 | 03:13 PM
awd2gen's Avatar
there is a water temp sensnor on the the back. Im hoping this one is not a water temp sensor because there is literally no plug for it any where. it almost looks like a ground. Its a flat piece of metal. only other thing in the entire engine bay that looks like it is the same thing on the starter that i believe is a ground.
Old May 14, 2010 | 07:18 PM
dubbleugly01's Avatar
the one in back (towards firewall) is the coolant temp sensor, and the smaller one up front is the temperature sending unit.
Old May 14, 2010 | 08:00 PM
awd2gen's Avatar
Temp sensing unit...can you explain? And I don't have a plug anywhere on the harness, everything else is there except this. No cut wires or anything..
Old May 14, 2010 | 08:04 PM
struggling to attach the link.....
www.trademotion.com/partlocator/index.cfm?action=getJointLocator&siteid=214857&cha pter=&Sectionids=0,2308&groupid=51823&subgroupid=3 317&componentid=0&make=24&model=Lancer[/url] Evolution&year=2003&graphicID=6265035&callout=23&c atalogid=2&displayCatalogid=0
if it doesn't come through as a link, go to autocenter.net, type in the vehicle and drill down to the illustrations of the parts.
ie, Evo, cooling, radiator and components, sending unit, water temp, view illustration. The harness should have a single spade plug, just like on the power steering pump.
Old May 14, 2010 | 10:39 PM
awd2gen's Avatar
Yeah definitly not on harness. But your saying it's one single wire right? If so I'll try and figure out the pin out on ecu and run a wire and splice at ecu.
