fpblack set up issues *need help*
Old May 14, 2010 | 12:11 PM
suprafabs's Avatar
whats up guys after 3 trips to the dyno and a lot of scratching head i cant figure it out whats wrong.... car has fpblack 25psi stock motor, kelford 272 cams ets 4" wide tank intercooler only put out 400whp everyone i talk to says car should be making least 450-460whp at 25psi..also if i set it up to 27psi boost will drop and go back up....... i have done boost leak test and acording with the shop its good, also timing on the belt is right on the money....once in while get a check engine light saying timing advanced....if i clear the damm light ill come back on maybe 2 days later regarless how much i beat on the car.....
**using dynojet dyno place is tsadyno in Jamaica, queens, runing fp 25psi actuator and have forged bov, we had reversed it at the dyno to test if was it, but still no change
what are your suggestions?
thanks
Last edited by suprafabs; May 14, 2010 at 05:14 PM. Reason: using dynojet dyno place is tsadyno in Jamaica, queens, runing fp 25psi actuator and have forged bov, we had reversed it at t
Old May 14, 2010 | 12:18 PM
evoboi005's Avatar
i got a check engine light saying timing over advanced when i had installed my cams and the pin in the camshaft had missed the whole in the mivec gear for pin to go into.... (pin slipped inside the camshaft) once i reset that and made sure the mivec gear was pre-rotated to the the rear of the motor when doing the timing
Old May 14, 2010 | 12:21 PM
evogirl916's Avatar
if boost is falling and rising...theres a leak! not sure about timing advance code tho
Old May 14, 2010 | 12:23 PM
evogirl916's Avatar
#'s vary from dyno to dyno also
Old May 14, 2010 | 12:24 PM
shh!! sleeping's Avatar
Who is tunning your evo and what dyno are you guys using?
Old May 14, 2010 | 12:25 PM
Also what waste gate and blow off valve do you have?
Old May 14, 2010 | 12:46 PM
suprafabs's Avatar
using dynojet dyno place is tsadyno in Jamaica, queens, runing fp 25psi actuator and have forged bov, we had reversed it at the dyno to test if was it, but still no change....the tuner Hercule...
Old May 14, 2010 | 12:58 PM
binky's Avatar
What's the actual code its throwing... P0xxx ?
Also, please post complete mod list.
-Bink
Old May 14, 2010 | 05:07 PM
bbyevo8u's Avatar
mod list would help maybe your missing something kean, also if your making 400whp on a mustang dyno thats not bad for 93oct & low boost!
also if boost is bouncing around then you prob have a boost/vac leak or leaky dv
Old May 14, 2010 | 05:26 PM
Evoryder's Avatar
could be o2 housing related. boost leak test. wastegate preload.
Old May 14, 2010 | 05:55 PM
sparky's Avatar
How are you controlling boost? Have you attempted to turn the boost up past 25#? 25# is pretty wimpy for the Black through a 4" IC.
Old May 14, 2010 | 06:10 PM
cij911's Avatar
A few thoughts :
(1) Pull the code and folks will be able to give you more valuable input
(2) 400 whp @ 25 psi peak tapering to X psi at redline sounds about right to me (maybe a little low), but it is hard to say w/o knowing what stock cars put down on the dyno
(3) Post the dyno w/ boost logged and folks will be able to give you more insight
(4) Post a log of a few street pulls - my guess is you are knocking and pulling a bunch of timing
Old May 15, 2010 | 02:04 PM
suprafabs's Avatar
ive gone um in boost but the hp barely goes up...like at 29psi i made 450...lolz
Old May 15, 2010 | 05:27 PM
I just spoke to E today... and he just told me that... you make 450 on the dyno... thats good man.. your on a stock block so play it safe... push it more and youll blow another motor...
Old May 15, 2010 | 09:03 PM
sparky's Avatar
I like tinkering with wastegate preload settings and from what you have described I'll bet that your WG may be set really loose with hardly any spring pressure.
What are you using to control boost.You wouldn't happen to have a boost log from that dyno session would you?
