oil pump pully has resistance when turned?
okay to start i just had my motor stroked out and im puting it back together, it hasnt ran yet. the balance shafts have been eliminated and a gsc race balance shast installed. now after oil pump was installed it has resistance every 90 degress when turned? should it spin completely free or should this be like this? alittle help im new to this site but have owned my evo 9 for 4 yrs now.
don't run it like that obviously. did you use a new front cover or install the new shaft into your old cover. I heard of a similar issue when re-using a cover, it can get gaulled while taking it apart
alrite took the cover off and inspected the balance shaft it seemed straight and it spun freely when out. so i reinstalled it continulously spining the pump while i tightened up the bolts. there is some resitance but nothing like before. thanx for all ur help guys!
really did u still have a shaft still behind your pump? cause mine did that on the bench but not after i reinstalled it. i just figured it was cause of the close tolerances of the bearing
