Need help asap..suppose to tune in am
Old May 19, 2010 | 12:34 AM
awd2gen's Avatar
I cant get acd to bleed the way everyone suggests by opening bleeder, turning key to on, and pressing gas pedal all the way down. Doesn't sound like acd pump is coming on at all. Suggestions? What I'm doing wrong? Anything?
new issue. I know for sure the acd is bled but still getting the 3 lights after driveibg about half mile. How do I reset it? Or what's the issue now?
Old May 19, 2010 | 12:38 AM
awd2gen's Avatar
Just FYI I'm using aem if that makes a differnece.
Old May 19, 2010 | 05:26 AM
awd2gen's Avatar
Anyone?????
Old May 19, 2010 | 05:56 AM
ReapingEVO's Avatar
Is it just you doing it??? you need two people
Old May 19, 2010 | 05:58 AM
ReapingEVO's Avatar
It takes 2 people to do this. One will sit in the driver seat and the other will be under the car opening and closing the bleeder. Turn the key to the on position. Step on the gas peddle and hold it to the floor then the person under will crack the bleeder as soon as the peddle is pressed to the floor. Repeat the step about 5 times or till it stops pumping air out. Make sure you keep an eye on the level of the ACD
Old May 19, 2010 | 06:59 AM
awd2gen's Avatar
Ok I'll try again
Old May 19, 2010 | 07:00 AM
awd2gen's Avatar
Also even the way I was doing it pump wasn't powering on at all
Old May 19, 2010 | 07:07 PM
awd2gen's Avatar
Bump for new issue.
kyoo
618
Jul 27, 2022 11:38 AM
Jaeger19
Sep 29, 2011 09:23 PM
>Cataclysm<
14
Sep 7, 2011 10:14 AM
hpgirl
11
Jul 13, 2009 12:08 PM
FastAzzEvo
Jan 12, 2009 12:52 PM
