View Poll Results: The "best"?
Hallman
111
63.79%
TurboXS
50
28.74%
MMi
0.57%
Generic/Homemade
12
6.90%
Voters: 174. You may not vote on this poll
POLL!! Best MANUAL Boost Controller
I know i'm asking some stupid questions, but i want to be sure before installing a turbo booster and a gauge.
What is the PSI on a evo8 turbo when it's running without a turbo booster?
What is the maximum PSI the engine/turbo can take ?
No danger to boost the engine/turbo ?
Thx
Thx
Hallman Evolution Pro is the best I think.
Excellent quality and ease of just turning the knob you dont have to have another wrench to set it. Plus you dont have to open the hood you can do it from inside the car. And if you use the grommet and hole thats on the passenger side you dont have to drill anything on the firewall.
My vote went for the Hallman, you can get them from www.boostcontroller.com for around $45 or so.
I had nothing but good luck with this part on both of my last turbo cars. (Holds boost and helps with spool up on the larger turbos).
I have the perrin It is a very good boost controller. Best of all it is cheap you can them all day for 89.99 but you can find them for 75 every once in awhile. I work just as good as any other boost controller. And is very easy to install and adjust.
Ben
Ben
i have turbo xs hp 1 and im having HELL of problems im hitting fuel cut around 15 psi. i can turn it up to 20 the turbo spools but doesnt throw it to the eninge...Cant figure out whats goig on if any1 has any ideas PLEASE pm me
Dejon Tool.
$50, rocks up fast, holds solid to redline, easy to install.
http://www.evotuners.net/forums/showthread.php?t=335
