Serious and Weird issue, HELP!!
Old May 21, 2010 | 03:39 PM
TKEVO's Avatar
Veteran: Air Force
well for the most part and still having oil issues but I found the problem and need to know if my theory is correct.
As shown in the pic, the threaded hole in the middle is where the oil is spraying from. Very very little in idle when when you give it gas, it comes out much more. I put my mirror in front of the hold and yes it's coming out of there.
Now could this oil be coming from when oil was leaking inside (spark plugs and below) and it is blowing it all out or am I wrong?
*NOTE* This hole is located on the block near the down pipe. There are 2 of these holes (One right behind the o2 housing and other near downpipe and above J pipe)
Old May 21, 2010 | 04:39 PM
psphinx81's Avatar
there is supposed to be a bolt there..
was your timing belt recently done?
Old May 21, 2010 | 08:06 PM
TKEVO's Avatar
Veteran: Air Force
Its not mine its my boy and no timing belt wasnt done. Only has 22k on the clock.
This whole is at the bottom, on the front of the block. There are 2 of them but the one Im referring to is in front/near the down pipe. Found out that this is the balance shaft alignment tool hole. GREAT!!!!
Yes a bolt is suppose to be there. What in the world did they do when they worked on his ride.
