Please help! my car wont start..
Old May 23, 2010 | 06:16 PM
BlueEvo8JDM's Avatar
Today a friend and I finished rebuilding my motor. But when i tried to start it i got nothing. The starter sounded, but the cams and everything else did not move. does anyone have any ideas what may have caused this to happen?
Its an evo 8 w brand new 2.4 block....
Old May 23, 2010 | 09:12 PM
a_awdgsx's Avatar
did the starter crank, or just whirred?
Old May 23, 2010 | 09:23 PM
pennies_hatchie's Avatar
Check timing, grounds?
Old May 23, 2010 | 09:26 PM
Spoolin4g63's Avatar
check timing, vacuum leaks and spark, good luck figuring it out..!
Old May 24, 2010 | 05:15 AM
the starter is work but wont crank the flywheel or suttin cuz then i tried to start and the sound liek stater n the cams wont even moving.. its jus weird.. everything is perfect and timing belt is perfect.. damn it..
Old May 24, 2010 | 05:53 AM
sharkm87's Avatar
can you turn the crank yourself? should be able to put a rachet ...i belive the passenger side and turn the crank with a 1/2 inch
Old May 24, 2010 | 08:24 AM
yah, i did tha.. its perfect moving smooth and no hit valves... Maybee the starter is no good after i took it off cuz the old 2.0 block was blew out maybe it cause the starter no good?
Old May 24, 2010 | 03:56 PM
The starter work good now and......... >>>>>>>>>>> when i turn the ingition on and the lights wont come off like service engine , battery, anti lock, brake lights wont come off then i turn ignition on and wont even start up.. Need help pleasee...
Old May 24, 2010 | 04:15 PM
and tried to start the motor up and no spark.... what to do? coil is no good or?
Old May 24, 2010 | 05:32 PM
forget it.. i got it.. cuz i put wrong way of sensor for spark by the crank it was backward so now everythign perfect now.. lol
Old May 26, 2010 | 06:20 AM
sharkm87's Avatar
lol..happens!!...great that its resolved
