how to adjust cam gears
Old May 26, 2010 | 06:37 PM
turbo dragon's Avatar
not 100% of which way to turn the adjustable cam gears to retard the timing, do I turn the cam gear counter clockwise to retard or turn it clockwise, thanks for any help guys
Old May 26, 2010 | 06:43 PM
03lan-evo's Avatar
in my experience you turn the gears away from the firewall to retard timing and toward the firewall to advance.
my thoughts on this are if the engine spins clockwise (from fire wall to headlights while your looking at the cams.) you will advance the timing if you turn the gears to the opposite direction (counterclockwise)
but dont quote me the big dogs will jump in an help more i just saw the post first LOL
Old May 26, 2010 | 08:30 PM
dsevo's Avatar
The motor spins clockwise, so if you want the cams advanced you would spin the center section of the cam gear clockwise (the part of the gear the cam is bolted to).
Old May 27, 2010 | 02:21 AM
thanks guys
Old Nov 22, 2010 | 12:22 PM
05VIII's Avatar
So which one is it? Both guys above have different answers
Old Nov 22, 2010 | 12:28 PM
erickponce's Avatar
think of it this way. If the engine spins clockwise, then if you turn your gear clockwise it will see the valve open/close events sooner so its advanced. If you turn your gear counter clockwise it will see the same events later so its retarded.
clockwise = advance
counter clockwise = retard
Old Nov 22, 2010 | 06:40 PM
C6C6CH3vo's Avatar
Your advancing the cams relative to the belt. So if you keep the crank stationary and spin the cams CW your advancing them. This is the same as spinning the outer ring CCW with cams stationary.
Advancing the exhaust valves decreases overlap and expansion stroke. Retarding intake valves decrease overlap and compression stroke.
Abacus
Mar 12, 2016 07:44 AM
kanovic
Dec 13, 2015 01:19 PM
overdrive1
May 15, 2014 09:52 AM
anthonypazsd
Jan 31, 2010 03:01 AM
trinydex
Mar 29, 2007 05:40 PM
