OEM Headgasket
Old May 28, 2010 | 08:16 AM
mindoftw's Avatar
OEM Headgasket
Is the OEM headgasket good, or should i go for an aftermarket headgasket like the one cosworth has?
And also i am going to be doing a water pump and i see that auto zone has a much cheaper water pump for our cars than what i see on lancer shop, just seemed strange to me.
Old May 28, 2010 | 08:20 AM
dubbleugly01's Avatar
the OEM headgasket is fine.
I'd stick with an OEM waterpump though.
Old May 28, 2010 | 08:26 AM
mindoftw's Avatar
Would you say that an OEM timing belt is also good? Or should i go with a stronger one?
Old May 28, 2010 | 08:41 AM
OEM timing belt is fine, just change it every 60K miles. The stronger timing belts have been suspected of causing oil pump failure due to overtightening and no 'give' in them.
Old May 28, 2010 | 08:50 AM
mindoftw's Avatar
Oh okay thanks for the information, appreciate it.
