??? on main bearings
Old May 30, 2010 | 09:17 AM
travail's Avatar
Can you put in new main bearings in a evo 4g63 with the motor still in the car like you can in the DSM 4g63 motor's.
Old May 30, 2010 | 09:24 AM
tkklemann's Avatar
Yes you can.
Old May 30, 2010 | 09:25 AM
buchnerj's Avatar
Yes, it is possible.
Old May 30, 2010 | 05:30 PM
MRfabolous's Avatar
how do you get to the main bearings on the other side of the crank i know it is pretty easy to replace the rod bearings.
Old May 30, 2010 | 07:19 PM
travail's Avatar
You would have to slide the bearing in till its in the right spot with some good motor assembly lube.
