evo 9 block in evo 8 ???
Old May 28, 2010 | 09:24 PM
N33d4sp33d's Avatar
can an evo 9 block be a direct drop-in into an evo 8 ???? Is there anything needs to be modified, fabricated ?
Old May 28, 2010 | 09:26 PM
buchnerj's Avatar
This has been discussed before many times. Yes the block will drop right in. You will need a Evo IX ECU to control the MIVEC, you will also need to run an oil feed from the Evo VIII block to the MIVEC head.
Old May 28, 2010 | 09:27 PM
jmelocik's Avatar
Block off the oil feed hole for the Mivec if you plan to run the VIII head.
Josh
Old May 28, 2010 | 09:28 PM
RockmanX's Avatar
there you go before i could even answer it.
Old May 28, 2010 | 09:37 PM
jbenosa's Avatar
so if i wanted to put my evo 8 head on the evo 9 lower end block, i wouldn't have to make any type of changes? it'll connect just fine?
Old May 28, 2010 | 09:39 PM
buchnerj's Avatar
It will fit. You have to block off the MIVEC oil feed on the IX block. That is it.
Old May 28, 2010 | 09:47 PM
N33d4sp33d's Avatar
what abt running a 2.4L 4G64 block with evo 8 head ????
Old May 28, 2010 | 09:55 PM
buchnerj's Avatar
You will need some special items for the 2.4 alone with either the IX or VIII head. Water pump spacer, special timing belt (or if you go OEM you need adjsutable cam gears to make up for the deck height), ported head gasket. Rockman knows all about this one . I ran into some issues too with my 2.1. The 4G64 is less of an issue for the VIII though, just those parts and your done, if its mating up with a IX head then again, you need to run the oil line up the back of the motor...
Old May 29, 2010 | 07:22 AM
RockmanX's Avatar
I sure do buddy on that note ill make a list for each
evo 8 2.4 parts needed
Longer Timing belt(a 4g63 belt will work but you have to stretch it over idler pully) can order proper belt from SBR
Water pump adaptor( Get the adaptor system from SBR or wield it in place you choose)
Adj Camgears(have to adj them 3.75 to make up for the 6mm deck height)
Headgasket you need to get one thats 87mm bore size(horsepowerfreaks.com=powerenterprise or AMS custom 4g64 like i have)
everything else is interchagable from the 4g63 motor
evo 9 2.4 parts needed
Drill a hole in the back of block for the oil feed line for the Mivec in the head.
There you go whats needed on each to get a 4g63 head(evo8,9) to mate with 4g64 block
Old May 30, 2010 | 07:23 PM
N33d4sp33d's Avatar
niceee...seems like an easier way to go with evo 8
Old May 30, 2010 | 07:29 PM
buchnerj's Avatar
The 4G64 actually has an oil port on the back of the motor, at least my 2.1 from BR had one. All I had to do was run a -AN fitting from that port up to the oil feed for the IX MIVEC head. I am not sure what this port was initially used for, either an oil pressure sensor or some other type of oil feed, but it can be used as a feed for the head. I double checked this and it runs great on my car. Even double checked to make sure MIVEC was functional during tuning and it was working without a doubt.
Old May 30, 2010 | 07:56 PM
RockmanX's Avatar
yes it is!!! but really any built block is gangster it shows your ready to grow up and your serious about making power with higher limits in mind
Old May 30, 2010 | 08:00 PM
sharkm87's Avatar
is the evo 9 block stronger than evo 8
Old May 30, 2010 | 08:01 PM
buchnerj's Avatar
No.. the only difference is the MIVEC head. The blocks are identical.
Old May 30, 2010 | 08:25 PM
RockmanX's Avatar
not a very smart question but as stated evo 8 and 9 are basically the same car minues mivec in the head exterior goodies guages etc. Ill tell you what you will see more bada$$ evo 8s going fast breaking records etc but does not matter at end of the day evo is a evo hommie unless its a evox
N33d4sp33d
15
Oct 7, 2013 04:15 PM
N33d4sp33d
For Sale - Cars For Sale
11
Aug 4, 2012 01:39 AM
N33d4sp33d
19
Jul 22, 2012 08:18 AM
N33d4sp33d
28
Feb 9, 2010 01:30 PM
rwlevans
Jun 18, 2009 04:06 PM
