Big problem, need help with rear LSD
Old May 31, 2010 | 07:37 AM
dambikeracer's Avatar
Drained the rear diff fluid, Redline Shockproof Heavy and when the drain plug was pulled, there was a christmas tree of LSD clutch pack pieces on it and the fluid was full of them. Did I blow my LSD? How bad is this? Do I need to replace the LSD to drive/drag race it? If this has happened to you before, where do I need to go from here?
Old May 31, 2010 | 07:48 AM
buchnerj's Avatar
Well, the only option you have is to drain it completely, and fill it up. Take it on a cruise and see if you hear any noises or vibrations. Drain the fluid after a good spirited drive and see what it looks like. If you already see particulate in the fluid then I would say you have an issue. If not, there is no harm in running it more. Chances are if it goes you are going to have to replace the internals already, so just get all the life out of it that you can.
When you can afford some down time and also the price of the rebuild, give Shep a call. I know they do rear LSD's for our Evos. Not sure on price though.
Sorry to hear about your luck.
Old May 31, 2010 | 10:01 AM
KenMasters's Avatar
Jacks has one sitting in their shop.
Old May 31, 2010 | 10:14 AM
Picking up a used one from Shawn
Old May 31, 2010 | 10:25 AM
apagan01's Avatar
sorry to hear,,, now metal particles is normal in the drain plug in any system.
you are making it sound like there is more than you are accustomed to see. did you hear any chatter back there before you drainned ?
Old Jun 1, 2010 | 10:53 AM
Already installed a new/used clutch pack in the rear LSD, it was blown up! I think running that shockproof heavy in the winter killed it. But I'm sure the 150+ drag strip launches did not help. Also made the move from Redline to Amsoil SVT 75w-110, we'll see how it does.
Old Jun 1, 2010 | 05:22 PM
Paul Walkin's Avatar
How often did you go on each Shockproof change?
What color was the fluid when drained?
Old Jun 1, 2010 | 09:11 PM
First 50K used OEM LSD Diaqueen, last 10K used shockproof heavy. Not sure the color, not the one who drained it. But it was chunky, blew the tip off of every clutch pack piece.
Old Jun 1, 2010 | 09:25 PM
lillev23's Avatar
Thats why I stuck with OEM Diaqueen in the tcase and rear diff.
Old Jun 2, 2010 | 09:25 AM
apagan01's Avatar
you will not look back after using SVG or SVO these are very friendly for LSD units.
i am curiouse to see how it performs with the oil in your case where you say that you drive the car hard. keep me posted through pm's
