Gearbox and LSD confusion
My mechanic in China just changed all the fluids on my Evo 9 recently and i was wondering if he used the right liquids...
He used this oil in both my gearbox and LSD, ACD.... is this correct ? I know this is what everyone recommends for the LSD and ACD but how about the gearbox ? What do u guys use ?
Thanks
Thanks
That stuff is not for the transmission.
Diaqueen is for the transfer case and the rear diff (anything with a hypoid gear). You need a regular gear oil as noted above for the transmission. Make sure you get this right or it's potentially a VERY expensive mistake for $30 worth of fluid. See links below:
Transmission fluid:
http://www.teamrip.com/manual_transm...tion_info.html
Transfer case
http://www.teamrip.com/transfer_case...tion_info.html
Rear Diff
http://www.teamrip.com/rear_axle_hyp...tion_info.html
Link to all the info:
http://www.teamrip.com/faq.htm
John
Transmission fluid:
Transfer case
Rear Diff
John
jameswwt
May 5, 2011 03:05 AM
MikeColangelo
May 25, 2009 03:06 AM
