264/272 MiX
264/272 MiX
I have only a limited knowlegde on cams in general so.......
When EVO cams were first being installed everyone was matching 264/264 or goin 272/272 now it seems most are settling with 264/272 MiX.
Some1 care to fill me in on why this is or is not the better choice?
Re: 264/272 MiX
I will say this 264 idle good
264/272 idle not so good
272/27 also idle not so good.
I think the 264 if you sticking with the stock turbo on a street car.
Eric
Here is some background info gleened from the Evo manual.
I believe someone asked about the stock cams in another thread.
The intake cam: opens valve 17deg BTDC; closes 59deg ABDC.
That is a duration of 256 degrees.
The exhaust cam: opens 57deg. BBDC, closes 15deg. ATDC.
That is a duration of 252 degrees.
This also gives you 32deg. overlap ( the time both valves are open ).
Going to a 264 cam on the intake isn't that much of a stretch from stock. Just 8 degs.
I assume there is more lift involved; this is where the big gain would come in.
The farther you push the valve open, the easier the air path gets.
Going from 252 to 272 on the exhaust is a bit more- 20degs.
But the longer the valve stays open, the more exhaust you can push out.
Also I assume there is more lift.
Also the overlap increases. If we assume the cam durations are centered over the old ones,
then the overlap goes to 46degs.
I believe this why you hear engines idling kinda lumpy with cams.
I will be looking to put in a 264/264 combo.
I want some more power, but not mad power.
Re: 264/272 MiX
https://www.evolutionm.net/forums/sh...3&pagenumber=1
http://www.automotosports.com/cam_test.asp
that was the study 954DRGSR was referring to
very informative
very informative
you don't need to go with the cam gears although it would be a plus. a lot of people are running these cams and te 272's with out adj. cam gears and they are fine. however, you might be able to squize a little more hp with the adj. gears providing you have a good tuner which can use them right.
