coolant leaking out of side of block
Old Jun 5, 2010 | 12:22 PM
def1's Avatar
Ok guys Im having a major problem Im losing coolant out of the side of my block Im just not sure exactly where. It comes from behind the lower timing belt cover right next to the crank pulley. What is back there that could be causing coolant to leak out. Its a rather big leak it leaves decent sized puddles under the car and my radiator fluid is low.
The car still drives fine but does occassionally puff white smoke from the exhaust sometimes. I can still boost but power seems to be a little down.
What do you guys think is the problem here?
Old Jun 5, 2010 | 01:10 PM
grim~'s Avatar
leaky headgasket possibly
Old Jun 5, 2010 | 01:52 PM
Drifto's Avatar
Water pump seal has gone bad most likely given your description
Old Jun 6, 2010 | 08:05 PM
AngryEvo8's Avatar
Waterpump is most likely toast. Happened to me, started leaking out the weep hole next to crank pully.
Whats the mileage on the car?
Old Jun 6, 2010 | 08:12 PM
evo unknown's Avatar
What year is your car and mileage? Are you overdue for a water pump/60k mile maintenance? Sounds like either a bad water pump or bad head gasket.
Old Jun 6, 2010 | 08:17 PM
05ah8james's Avatar
If the head lifted enough for coolant to leak like you're describing, you'd definitly notice discoloring in the coolant itself. Is this the case?
I'm gonna jump on the bandwagon and vote for the water pump. I know you're really not gonna wanna hear this but you should stop driving that thing and get it fixed asap. If coolant gets on your timing belt and it slips, it could cause you serioUs heartache.
Old Jun 6, 2010 | 08:21 PM
+10 lol... stop driving and get this fixed now!
timv
16
Jun 6, 2021 03:11 PM
MitsuJDM
38
Nov 23, 2016 11:49 AM
AcePitcher11
Jan 19, 2010 12:52 PM
mugen777
Oct 31, 2008 07:07 AM
Travis
Apr 16, 2003 12:01 PM
