Installed twin disc now noise when off throttle!!
i need some help, just finished installing my quartermaster twin disc and everything seems fine except when i am in gear and let of the throttle i will hear a loudd noise coming from the engine drivetrain area.
When i let off the gas and it makes that noise if I put it in neutral it will go away as soon as i put it in any gear again without giving gas it will continue to make it???
I noticed if im driving after 70mph +/- and let off throttle I wont hear it but as soon as the mph drops the noise will appear
The noise sounds like metal grinding or something metal rubbing up?
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
drivetrain noise is normal with multi disc clutches. If you don't mind me asking how much power are you making why you need a quarter master.
It is very normal. Some clutches are worse then others. Seems ones with springs in them are usually more quiet as the spring eat up the vibration.
-Em
I have the same problem man. I know its normal, but its beginning to be very annoying! lol I had a straight pipe exhaust on the car up until now. My new exhaust(ebay catback, w/megan downpipe) is much quieter than the straight pipe exhaust. Now the clutch is really starting to bother me since I can hear it so much more!
I was thinking of getting rid of it, but I know its a badass clutch! Not sure what ill do?
its real loud under Deceleration like somethings going to break lol
