Installed twin disc now noise when off throttle!!
Old Mar 15, 2010 | 01:19 AM
Evo_TK's Avatar
Yeah its normal my QM does the same
Old Mar 15, 2010 | 03:24 AM
1NastyMR's Avatar
Totally normal stop freaking about clutch chatter when your off throttle.... just about every twin disk does it
Old Mar 15, 2010 | 05:32 AM
tsidrift1's Avatar
So, I read through some of the posts in that link. I am having the vibration too, associated with the noise, which, I know is normal. Is the vibration normal too?
Old Mar 15, 2010 | 05:54 AM
millsyy17's Avatar
Veteran: Army
Originally Posted by k20toEVO
Are you trying to get him killed? These things have stuck gas pedals
He would be in the car doing this..
No worries guys i work for toyota with the "stuck" gas pedals lol we have the
"fix" for it
Old Mar 15, 2010 | 06:03 AM
millsyy17's Avatar
Veteran: Army
Originally Posted by jasonn
Thats EXACTLY what my car does..so everybody think this noise is normal from the clutch? Just want to make sure Im not going to damage anything
Old Mar 15, 2010 | 07:32 AM
Skipmaster J's Avatar
... are you hoping for somebody to tell you there's a problem?
It's normal.
That's not to say zero damage is being done - but that's part n parcel of having a more aggressive clutch. Your gearbox will probably be under increased load due to the unsprung nature of the discs but I'm not sure if this will have a measurable effect on longevity or reliability.
Old Mar 15, 2010 | 08:10 AM
MrHouse's Avatar
This is normal. Just stay away from hard launches to save your t-case and tranny.
Old Mar 15, 2010 | 11:31 PM
jasonn's Avatar
I heard it may be your throw out bearings.
Old Mar 16, 2010 | 12:22 PM
kyoo's Avatar
shoulda tried exedy twin.. i have almost ZERO noise
Old Mar 16, 2010 | 12:28 PM
dave_evolvix's Avatar
Should've researched before you got that twin disk. Its the #1 daily driving complaint with twin discs.
Old Mar 16, 2010 | 02:49 PM
Arkitek's Avatar
that makes no sense at all. This thread IS about a twin, and twins DO make a lot of noise....it's normal
Old Mar 16, 2010 | 03:02 PM
xRoguex's Avatar
OP - what did you think you were getting in to when you bought an unsprung twin capable of single digit passes...?
Old Mar 16, 2010 | 03:34 PM
TTP Engineering's Avatar
Wrong on many levels. There are no "throw out bearings" There is a throwout bearing, but in this case, it is a push style clutch with a hydraulic release bearing. There is NO THROWOUT BEARING.
The decel would appear to be normal. Personally I do not have that noise on my own Quartermaster Twin.
boostless's Avatar
great oxymoron....ALMOST ZERO noise huh? So it makes some noise (which is normal)
Old Mar 16, 2010 | 11:37 PM
jasonn's Avatar
Ah got it, thanks for the correction.
