aem uego gauge suddenly shut off!!??? WHY???
Old Jun 6, 2010 | 05:12 PM
Evoleader88's Avatar
today when i pulled out of my driveway, mye aem uego gauge turned off. But my boost gauge and oil pressure gauge still light up and workin normal ( note: my boost and oipressure gauge are Autometer) . i checked all the power wire and ground, they were fine. all guages hooked up to the same ground and power source but only my aem uego shut off for no reason and the others 2 working fine. Is it somthing wrong with the guage or wire. plese help!!! cuz this driving me nutttt
Old Jun 6, 2010 | 07:27 PM
no answer for this prblem?!?!?!?!
Old Jun 6, 2010 | 07:45 PM
Red Baron's Avatar
check and re-check all your connections that happened to me too and it turned out to be the ground wire came loose. good luck!!!!
Old Jun 6, 2010 | 08:38 PM
ok,
1st i have all the gauges power hooked up with 1 of the power wire from the radio harness. and the 2 autometer ground wire hooked to my turbo timer ground, the uego ground was totally seperated, it was hooked to one of the bolt that go straight to the car chassis under the shifting console
2nd i blew 1 of the 10a fuse n my radio and my clock as well as my 3 gauges shut off. then i replaced the fuse and hooked the power wire for the 3 gauges with the cigaret lighter power wire which has a fuse 15 i think, and remain the same grounding. then it seem working fine till today my AEM uego die on me. i
3rd i recheck the ground for the uego but it looks fine, for sale i switched it to the same ground with the other 2, Still not working.
IDK wat happend, No clue right now
Old Jun 6, 2010 | 08:42 PM
sparky's Avatar
This happened to me and the connection under the car to the O2 sensor had become disconnected.
Old Jun 7, 2010 | 03:20 PM
i did check that too n its fine
seven10
Sep 18, 2015 03:49 PM
2012evogsr
Evo X How Tos / Installations
Oct 23, 2012 06:23 AM
kimma
Jan 30, 2012 04:19 PM
onyx1121
May 17, 2011 03:19 PM
evo 9 guy
Nov 16, 2010 11:49 AM
