aem uego no gauge redout but does have power??
Old Jan 30, 2012 | 02:39 PM
kimma's Avatar
my gauge was acting goofy this weekend ..giveing me high lean readouts and then the next day it does not work at all. no redout. the gauge doesnt even light up. i checked the wires on the back of the gauge and it does have power. the ground is good and the connector is fine along with the wires. when the sensor goes bad. does it just shut off. my uego is a couple years old. what to do
Old Jan 30, 2012 | 02:51 PM
awdturbo8's Avatar
Mine went out after 8 months. I would just re
awdturbo8's Avatar
Edit ^^I would just replace it
Old Jan 30, 2012 | 03:14 PM
Svendiesel's Avatar
Try replacing your sensor before goin nuts. I cant recall if there was a blank reading on mine when my sensor went or if it displayed two dashes on the readout like "--" Since it had been working fine, its likely just the sensor and nothing more.
Old Jan 30, 2012 | 03:22 PM
sparky's Avatar
First, check that the sensor is screwed tightly down into the bung. Sometimes the sensor can back out and you won't get a reading. Otherwise, it is replacement time most likely, just as the other buds are telling you. GL
Old Jan 30, 2012 | 03:28 PM
kimma's Avatar
sensor is screwed in ...i just want some clerification that when these things go bad..real bad is there even a read out..because i am showing nothing on the gauge yet it has power..no 00 no dashes nothing..all wireing has been checked.
Old Jan 30, 2012 | 04:04 PM
sparky's Avatar
As a comparison when my AEM O2 went south, it became very limited in range tending to stay put on one number.
Old Jan 30, 2012 | 04:10 PM
awdturbo8's Avatar
If the sensor is bad it'll show "--". If you have power and ground going to it and it doesn't turn on or anything. I would replace is. If you have a friend that can loan you the gauge itself, test it that way
Old Jan 30, 2012 | 04:19 PM
03evo8racer's Avatar
Yeah man it sounds like the gauge it self went out. When my sensor went out it showed "--" on the gauge.
evoniners
Apr 1, 2017 11:32 PM
caliraised
Feb 18, 2015 09:03 PM
Svendiesel
Mar 7, 2014 12:42 PM
onyx1121
May 17, 2011 03:19 PM
Evoleader88
Jun 7, 2010 03:20 PM
