Forge 18 psi WGA
Old Jun 8, 2010 | 06:40 PM
evo8john's Avatar
Forge 18 psi WGA
Will this work on the 10.5 hotside 8 turbo as well? I know it is mainly marketed to the 9 turbo guys but i want to run my 8 as hard as it can and am needing to hold boost pressure a little more to redline and possibly help spool. Thanks!
Old Jun 8, 2010 | 08:17 PM
sparky's Avatar
Are you confusing the Forge VIII WGA with the Forced Performance 18# WGA? Whatever the case, you should call the particular supplier and specify that yours is an VIII turbo and not a IX turbo. The VIII and IX turbos each require a different actuator rod. So call the supplier and specify the turbo.
I twice ordered the Forge WGA for a IX turbo from Lancershop and both times they sent me the wrong actuator. So, be cautious.
Old Jun 8, 2010 | 08:20 PM
erald01's Avatar
yes it will work cause the wastegate controls the flapper on your hotside, when it opens and closes.
Old Jun 8, 2010 | 08:23 PM
EvoFredo's Avatar
im sure it would work the same . but post up what they said to you on that. and what kind of results you had with it. good luck
Old Jun 9, 2010 | 10:27 PM
evo8john's Avatar
thanks for the info on this... i will be sure to post up details if and when i do this upgrade.
Old Jun 9, 2010 | 10:36 PM
SRToad4's Avatar
In for details after installed (spool time / boost hold to redline / etc).
kakarot305
Dec 9, 2010 12:25 PM
sharky559
Nov 23, 2010 06:18 PM
evo8fate
35
Jan 11, 2009 11:43 AM
evo8fate
28
Apr 16, 2008 03:28 PM
Blue Oompa
Oct 27, 2004 09:09 PM
