transmission and tranfercase in a evo
Old Jun 15, 2010 | 12:53 PM
travail's Avatar
Question transmission and tranfercase in a evo
I found out that I have to put in new main bearing in and I am pulling the motor and transmission out together. I am at the point were I need to pull the shaft out of the transmission on the driver side that go's to the tranfercase. How far do's the shaft come out of the transmission so it's not in the tranfercase?
Old Jun 15, 2010 | 12:57 PM
binky's Avatar
You will have to pull both the axles out. One is in the transfer case on the passenger side and one is on the driver side.
If you are taking the engine / transmission out, both have to come out.
-Bink
Old Jun 15, 2010 | 01:03 PM
travail's Avatar
-Bink
I have both axles out. but I still have to pull the torque tube out of the T-case so the motor and the tran can come out. look at number 26 to 28
http://www.evomoto.com/tech_articles..._article_id=27
Old Jun 23, 2010 | 06:33 PM
dinoz1980's Avatar
if u are talking about the shaft that goes inside the tranny and to the tc then it has too come all the way out if u just get a quick and hard jrek on it it will come out ez it has a c ring on the end of it
Old Jun 28, 2010 | 04:18 AM
icantdrive75's Avatar
I hope you've figured this out, but I just did this today. You need a slide hammer. Search youtube for a transfer case removal video.
Old Jun 28, 2010 | 04:25 AM
30lbsboosted's Avatar
the shafts on both sides come all the way out and to remove tcase u will need to remove the tail dust shield if thats what thery call in
Old Jun 28, 2010 | 07:12 PM
travail's Avatar
I got the shalf out it all good thank for your input.
