dry sump...
Old Jun 15, 2010 | 02:22 PM
gary@apt's Avatar
dry sump...
hi guys
any of you using a dry sump system???
Old Jun 15, 2010 | 06:33 PM
JohnBradley's Avatar
Gary,
I think the only Evo I am currently aware of is the one that Magnus did the engine for. It is not a very common item for most Evo owners. We have toyed with using one on our Evo Drag Car this engine, but havent decided really.
Old Jun 15, 2010 | 06:41 PM
whtrice's Avatar
Veteran: Air Force
Found this from ARE
http://www.drysump.com/Mitsubishi.htm
Old Jun 16, 2010 | 12:04 AM
gary@apt's Avatar
the guys sprinting and track users are finding more and more the standard sump,oil pump are causing issues
we have a kit and would like to push it on here,whos best person to contact???
Old Jun 16, 2010 | 05:37 AM
03whitegsr's Avatar
Sierra Sierra I believe is using one. Considering the problems some have had with cornering causing engine failures from oil starvation, I'm surprised more haven't gone to dry sumps.
Brent Rau in his drag Eclipse I think ran on for a while, but I think he went back to a stock pump?
Old Jun 16, 2010 | 07:16 AM
CO_VR4's Avatar
Drag racing presents different oiling pressure problems, with different solutions.
A dry sump is the best overall solution for g-forces in many directions, because the oil reservoir holds several gallons of oil, and it can never run dry or cavitate, so the pressurized oil supply is always available to the parts needing it.
Old Jun 16, 2010 | 07:24 AM
gary@apt's Avatar
ive pm'd someone before getting some pics added here
Old Jun 16, 2010 | 09:24 AM
GRNMCH's Avatar
Another ulternative is Accusump (www.accusump.com), high cornering G DSMs have been using them since the early 90's!
They are MUCH cheaper than the drysump system and do the job!
Old Jun 16, 2010 | 09:26 AM
gary@apt's Avatar
think most of guys in uk have tried but dry sump is only proper answer to oil issues
Old Jun 16, 2010 | 10:56 AM
DynoDude55's Avatar
Originally Posted by whtrice
Nice Find!
I wonder how their oil pan fits to the block... I have an AMS dry sump and the Moroso Pan is not very flush with the bottom of the block. I called AMS and they said it is an issue that Moroso is supposed to be working on.
I am also trying to find a decent location for the oil tank and keep the lines as short as possible.
Old Jun 16, 2010 | 11:06 AM
gary@apt's Avatar
heres link to our site with some info on there
http://www.ap-tuning.co.uk/EvoDrySump.html
Old Jun 16, 2010 | 11:32 AM
03whitegsr's Avatar
That's a nice clean solution you guys have come up with.
Old Jun 16, 2010 | 12:04 PM
DynoDude55's Avatar
I agree, nice design!
Old Sep 6, 2010 | 07:32 PM
willitas34's Avatar
Ya, that works great... unless you have two hard right hand turns back to back running hoosiers and the accusump can't re-pressurize fast enough....
Happened to SmackEvo here in norcal. Watched him pit quick style after the last 2 turns at Thunderhill in the CW configurations... not good.
Both of those dry sumps look great! Sucks to hear the Moroso dry sump pan is having issues... I have seen the same for the wet sump pan they produced for AMS
Old Sep 6, 2010 | 07:45 PM
cij911's Avatar
Man these are pricey, but I guess $3 - 5K is what it takes...ughhhh yet something else....this car is getting into 911 territory (price wise).
APT - Don't you need a special tank to separate the oil and air ? I did not see that or filtration on your web page.
