Upper I/C pipe, I/C chiller kit, or injectors & fuel pump? Which one?
Old Nov 15, 2003 | 09:57 PM
stvbreal's Avatar
Question Upper I/C pipe, I/C chiller kit, or injectors & fuel pump? Which one?
I'm trying to figure out which would be better to get. Any suggestions? I have a few modes. See my mods list.
Old Nov 15, 2003 | 10:05 PM
EvoJimbo's Avatar
Injectors and fuel pump....more fuel for tuning and HP!!!!!
Old Nov 15, 2003 | 10:11 PM
Zeus's Avatar
...and a dyno flash if you are local to any of his dyno days...
Old Nov 16, 2003 | 10:56 AM
alex_alex's Avatar
injector and fuel pump!!!
the I/C chillers don't do jack, and the I/C pipe shows MINIMAL gains
Old Nov 16, 2003 | 12:27 PM
Zeus's Avatar
...to add to that, you, of course, can support more boost with the injector/pump combo. (No bottle to fill etc.) You can crank the boost up with your EBC, and tune it with your AFC... an all the time power adder. Buscher defeated the fuel cut to a degree with the AFC and larger injectors. Hell, if you buy injectors and a pump from him, he will probably give you fuel settings that are about 85-90% on from the get go.
Old Nov 16, 2003 | 03:32 PM
zstryder's Avatar
Has anyone dynoed gains from IC piping?
IC piping is easily like $600-900, but damn... is this a bling thing, or does the hard piping actually do anything?
Old Nov 16, 2003 | 03:38 PM
Quickshift's Avatar
From what i understand about the intercooler pipe is that i give you a quicker spool up and more airflow, cause there is alot , ALOT of bends in the piping. With more flow = more power and the one buschar sells is about 330 (upper pipe) But you will also need a battery relo or smaller unit.
Old Nov 16, 2003 | 09:48 PM
umiami80's Avatar
IC Chiller ads 50WHP, temporary though. Get the upper IC pipe and it comes with a CRUSHED 1gBOV, best on the market for now.
