K24/K20 vs. 4G64 max rpms???
Great discussion!
have few questions:
1) Any idea what the stock evo head flows vs. the highly ported 295cfm head?
2) How many 2.4s have revved that high in the past?
3) How many of those 2.4s have failed due to high revving? and what were the guesstimated causes?
4) Any comparisons done between the honda and the mitsu bearings?
Hope Spyros from Extreme Tuners find this thread and comments. He seems to have alot of knowledge when it comes to building high revving engines.
have few questions:
2&3 answers are below
4) The Honda and Mitsu bearings are VERY similar.
#2 - I haven't seen many mitsu 100mm stroke engines successfully run to 9k and #3 does not need to be guessed at in any way shape or form. They wipe out center main bearings due to high bearing loads from a combination of light counterweights on the crank and heavy rotating parts. It may be possible to increase the counterweights to fix the bearing loads, but then all the bearing loads are very high. I'm attacking it from the lighter rotating parts point of view. I'm also trying some looser main bearing clearances this season to see if it helps. The bearing failure mode looks like overheating of the shells. At OEM clearances the center main bearing will be wiped out in somewhere around 20 passes.
Kevin
^^^^ At least with the B series, they sleeve them because they're an open deck design and past a certain point cylinder flex becomes an issue, and then of course to enable the use of larger sized pistons. An NA Honda B-series can rev to 9K reliably, but I wouldn't trust the bottom end to handle that with a lot of boost thrown into the mix.
I would, however put at Long Rod K24/K20 into a EG hatch LSD of course with a nice HTA3582! 600+hp in a 500lb car
SICK!!!!The 4G64/4G63s are great engineered motors and preform amazingly. there are not many other motors out there that you can run 500-600hp through a stock motor. Well the F20C can hold a great deal in stock form too...
Kevin, you have oversized bearings right? How did those help you? I think if we lighten our rotational mass we coud rev higher as long as the power is still there.
Mikey
I'm currently running intake cams and exhaust and making 330awhp on 91 oct...so why put a lesser motor in the car. Seems retarded to me.
i found it interesting about the comment of the 2.0 would walk the 2.4 on a highway on the street at the strip to the grocery store and to the house haaaaaaaa but on a track its king so i guess all us 2.3 2.4 DD guys made the wrong choice
Mikey
