who has - Coil on Plug NON CDI System
I put this cop on a friends race car that was making 700whp at the time he had major hiccups and ultra jerky idle. Once he put this on.. car drove perfectly... As soon as that happened I knew I had something special!!
Hre you go my man http://www.sparktechignitions.net/v2h-ycdi.html
thanks for the link!
do you think you need the cdi is the question ? if you are going to run alot of boost on a bigger turbo e85 or n2o i would say its the better choice but the sparktech non cdi is good for 700hp they say so do you plan on making more ? and do you wanna spend the money ? notice the price diffrence.
i think you miss understood me my friend. when i said they do make a difference i meant they do over a stock ignition... as for being proven i know they are so i stated that. sorry for the confusion
After seeing the craftmanship of both units, I would still have to vote for paying more money since there is a huge whole in the hood for water and everything else to come in on it. Just my 02 cents.
Harnesses are made from Military grade Teflon wire and high heat fiberglass sleeve. I only use Stainless Steel and Aluminum for mounting coils....no corrosion. All connectors are sealed fully so water is no issue.
Also, the New coil kits I offer fit under the valve cover.
https://www.evolutionm.net/forums/ev...w-hks-dli.html (Post #3)
It works great... more spark!
I'm running the SpoolinUp used kit... 40+ psi, E85, HTA35R
There has been no breakup with my plugs gapped at .28 / 617whp & 517wtq on a low reading Mustang. Will be going back to push it even further
ancient thread I know, but it seemed as close as I could find for my answer ... and yet it didn't so ..
Does anybody have any experience with the STM non-cdi COP?
https://stmtuned.com/products/stm-ev...gnition-system
Thanks
Thanks
