dual pump install now goes lean??
I don't see how that could create an issue. Even if the return line were wide open, that shouldn't prevent the FPR from doing its job. You can almost be certain that you will need to take it apart, check your wiring, and have a good look at things.
no
I would wire the second pump from the battery direct with a hobs switch and relay, only on while boosting, sounds like you're over loading the existing wiring.
i have not checked volts under boost yet, just at idle but i will be check under load tonight. lets say they volt do go low under load what should i check/change to try and correct it?
Sounds like one of the pumps isn't working to me. 40 psi at idle and 20 psi under boost? At 20 psi boost, you should see 60 psi fuel pressure. Sounds like once the fuel demand is up, the pumps(s) can't keep up. That big of a drop would seem like one isn't running to me.
How exactly is the second pump wired again? You know that the stock pump is on a dual circuit, right? A low voltage for idle conditions and a higher voltage for higher demand that is switch based on certain conditions. You're not tapping into the low voltage circuit, are you?
Where are they grounded? Any chance you are grounded off a switched circuit that loses ground for one of the pumps?
Voltage under load ideally should be as close to idle as possible, but depending on wiring, etc, it may drop a bit. I really don't think that's the issue here. The fuel pressure is dramatically dropping under boost when it should be rising.
My pumps see around 14v under load, with a power feed right off the battery (triggered by a relay). My ground is a dedicated ground for both pumps. If you see anything less than 13.5v to the pumps while under load, you're losing pump capacity.
A drop to 20psi under load is dramatic. That type of problem shouldn't be too difficult to isolate.
well once i get done with work tonight i will head to my shop and take pictures of the setup and how things are wired. that way you guys arnt guessing and can help me a little more since im not a wiring genious.
well like i said i got some picture and no laughing at the wiring job.
in tank pump relay wiring,
#30- constant power from battery
#85- relay ground
#86- spliced white wire on top of pump wire on car side "blue connector"
#87- spliced white wire on top of pump wire on pump side "red connector"
#87a- not used
inline pump replay wiring,
#30-constant power from battery
#85-relay ground
#86-signal tap on passenger side flood single white wire
#87-positive power ran down to inline pump
#87a- not used
here is some of the picture any ?s just ask n ill try to explainor if you see the problem let me know.
the relay lay out im using.... both are from the stm pump rewire kit
distribution power block
relay grounds
signal wire taped into for lower pump
lower inline pump ground
the white wire splice for intank relay
everything
lower inline pump position
#85- relay ground
#87a- not used
#85-relay ground
#87a- not used
relay grounds
everything
http://www.amsperformance.com/instru...l%20System.pdf
