Help! Quatermaster assembly with pics
I purchased a quartermaster twin disc from Maperformance
Great pricing and fast shipping btw!
The instructions are pretty vauge so I have some pictures with some questions.
This is the 2 disks, floater plate, and pressure plate I recieved
The first plate is already in the pressure plate. I install the disk with the longest hub first correct?
Then it makes sense to install the floater plate next
The last part confused me. The last disk with the hub, does the hub point towards the pressure plate?
Or towards the Flywheel
Thanks for any knowledgeable help!
Hey guys. I've got the PTT clutch which uses QuarterMaster parts (Some are just similar). I wanted to know if there's anything special about the spacers. You're supposed to do all this measuring and add spacers to get a clearance of .160", but when I added all the spacers that came with the kit, the release bearing depth doesn't change. Did you add these spacers, or do any of the measurements?
EDIT* Nevermind; question answered. The spacers are for a rebuild.
