Problem: Evo 8 - Welded rear diff.
Old Jun 24, 2010 | 08:41 PM
Liquid0401's Avatar
Ok, so this started couple days ago.. My rear end acts as if the diff is welded. When I make a sharp right/left turn you can hear and see one of my rear tires (depending which way im turning) sorta drag and skid to catch up with the others. This is the best as i can describe it. Its kinda like what happens to 240s when the weld their rear diffs. Anyways, so I took my car to my friends shop today. We took apart the whole diff and inspected all the teeth inside and aside from a well needed fluid change everything is fine. So we cleaned it up put some new fluid in her put It all back together started the car up and took it out for a spin and the problem is still there. WTF! I cant figure this out. Has anyone else ever had this problem? Any help/ideas would be appreciated.
wtf?
Old Jun 24, 2010 | 08:51 PM
Evo IX MR's Avatar
Maybe check the axles?
Old Jun 24, 2010 | 09:00 PM
bostonhatcher's Avatar
How much fluid did you drain out? It's possible it was low on fluid, and the diff got hot which seized the clutch packs together.
Take the cover back off and play with turning the axles individually.
Old Jun 25, 2010 | 12:53 AM
Liquid0401's Avatar
It was full on fluid but the fuild was really bad. It was black! Ive never changed it and now that I think about it I dont know when was the last time the previous owner changed it either.
Checked the fuilds on the tcase and the transmission just to be safe and those are fine. We are going to pull the rear diff off the car again tomorow and spin it like you said.. Do you know if the clutch packs can be ordered/ replaced individually without replacing a complete rear diff?
Old Jun 25, 2010 | 01:23 AM
Still_Spinnin's Avatar
I am 12, What is this?
Old Jun 25, 2010 | 01:31 AM
You'd have to check with the dealer. Give TRE a call as well about your problem and they'll give you more diagnostic tests and will also give you solutions once you figure out the problem.
Old Jun 25, 2010 | 01:47 AM
Quit trying to fix this damn diff and go get that shep diff fo' the low low!!!
Old Jun 25, 2010 | 05:21 AM
ozzy1's Avatar
Old Jun 25, 2010 | 05:35 AM
bluebanana23's Avatar
start saving up just in case
Old Jun 25, 2010 | 11:17 AM
Saving up......Pshhh.....We balllllin'!! lol
Still no new info on this. Should know something soon.
P.S. Ozzy gtfo.
Old Jun 25, 2010 | 07:32 PM
mithrandir7533's Avatar
Is it always the inner tire that is doing this? Why do you think this is the Diff.? Watch some road racing videos, there inner rear tires practically come off the ground.
Old Jun 25, 2010 | 09:02 PM
Liquid0401's Avatar
lol, i might have to.. go shep or go home!
Old Jun 25, 2010 | 09:03 PM
Liquid0401's Avatar
Yea its always the inner tire.
Old Jun 26, 2010 | 01:15 AM
Liquid0401's Avatar
Heres what it looked like when we took it apart the first time..
Old Jun 26, 2010 | 01:45 AM
Toxin's Avatar
If this "problem" has been there ever since you've got the car then the explanation is simple.
I had my IX rear diff set up exactly like that - just replace a few clutches and turn them so the rear diff "grabs" with more of them. In slow turns you could hear a click sound and driving slowly around the situation you explained is exactly what my car was doing. It was doing it intentionally though.
If some previous owner set up the car like that, you should only be happy, do more frequent oil changes (since the diff does more work as it is) and enjoy the oversteer
