jm fabrications intake manifold install how to?
Old Jun 25, 2010 | 11:28 AM
itr.#1446's Avatar
Is there any threads on how to install this manifold? I searched and haven't found anything. This is my first time doing a manifold on an Evo I am a mechanic and have done tons of other manifolds but I'm stumped on this one. Some questions I have is what vacuum lines should go to the manifold what is not needed, what should the bov be it'd into ect. Also since it has no map bung do I need a a speed density kit if I don't weld one on? And lastly where does the throttle cable get mounted to it has no spots from what I can tell to hold it on?
Edit: just found the spot for throttle cable to bolt it to the Mani was down on the bottom keeps the TB in issue original position no need to rotate I found the magnus thread I guess I will use to see how the vacuum should be ran.
