Front Wheel bearings
Old Jun 23, 2010 | 12:06 PM
GTisRule's Avatar
So, gonna do both front wheel bearings in about 5 minutes. I read thru the factory manual and it shows
Do I really need this tool?
Old Jun 23, 2010 | 12:16 PM
Svendiesel's Avatar
Trick my DSM friend showed me when we did my rear hub...you can actually just turn the brake rotor around on the hub, put 3 lug nuts on evenly on the studs to give the rotor some room to slide, then use the rotor to pull the hub off. You have to use some strength tho to get the hub to budge off.
Nothing was damaged when we did this, just watch out for your ABS sensor.
Old Jun 23, 2010 | 12:18 PM
GTisRule's Avatar
That totally makes sense, much thanks!
Old Jun 23, 2010 | 12:19 PM
Svendiesel's Avatar
No prob!
Old Jun 23, 2010 | 01:59 PM
SpoolinUp's Avatar
Silver Sponsor
I just beat the old one with a large hammer. The other one I went right on without an issue.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Jun 24, 2010 | 06:24 PM
Berts24's Avatar
you could rent a slide hammer from your local parts store but how did the brake rotor thing work out???
Old Jun 25, 2010 | 11:35 AM
20gmr's Avatar
I have done i think 5 of them and have never had an issue getting one out by hand once the bolts are removed.....F*cker is expensive tho haha
GTisRule
Northwest Region
May 2, 2009 04:18 PM
GTisRule
Northwest Region
Apr 15, 2008 11:12 AM
GTisRule
Northwest Region
24
Oct 11, 2007 04:17 PM
