First thing I've hated about my Evo in 1.5 years of ownership...
The front under cover... 28 plastic screws. Just spent $21 at McGlendon's on new bolts and misc. fasteners to make the tray easier to remove/install. What do most people use for these POS's? Don't push hard enough and you strip the screw head out, push too hard, strip the threads. I mean seriously, WTF does the dealer do? Is there a super trick screwdriver just for removing these?
The problem with tossing stuff like that, if you ever plan to keep a car for a long time, you learn the factory puts those covers in places for a reason. I also have a 89 GTi 16V that I've owned for 14 years. I can tell you ever screw hole you don't treat rusts, splash trays that make belts squeak, etc. I plan on keeping my Evo as I have the GTi, but at least with the Evo I'm the first owner, so I have to answer for every flaw the car has... Getting a rock chip while yer hauling *** enjoying the car is one thing, but tossing factory parts for stuff like that is one of my peeves... It must go back on! heh... I'll post some pics if I invent some engenious way to put it back on.
if you look at the undertray there is actual ducting to cool your brakes and i believe possible slight amount of down force, dealer mechanics have removed so many of those clips that it's kinda a learned art but i swear it takes me longer to remove that thing then to take the actual trans out
just get the none screw type that have a slit for a flat head, i put them on my subaru front bumper and i will eventually put them on my under tray, they work wonders, and make things sooooooo much easier.
Can you post some info on what you're talking about? I will replace it with ANYTHING that works 1/2 as well as the factory stuff. A pic, even a link to where they can be purchased from? I bought about 40 U-Clips of different arrangements, and I just don't like any option I've thought up just yet. I'm looking for ANYTHING else better than the factory's BS attachment clips.
I have the Beatrush under panel. IMO it was cheap enough, and has saved my front end many of times. It only takes a few minutes to take the back section off to change the oil. Here is the link to it. I highly recommend it.
https://www.evolutionm.net/forums/sh...d.php?t=224947
