Split my 2.3 4g64 crank in half !
Old Jun 28, 2010 | 11:40 AM
rh9's Avatar
rh9
Originally Posted by Ev0ikon
It's a piggyback correct? Who did your tuning?
No it's a complete standlone ecu
I do my tuning
Old Jun 28, 2010 | 11:42 AM
rh9's Avatar
rh9
Originally Posted by 20gmr
wow thats kinda cool. Maybe the harmonic balancer failed.
The harmonic balancer being the crank pulley ? No it is still in one piece !
Old Jul 7, 2010 | 04:00 PM
rh9's Avatar
rh9
any interchangable block with the evo's 4g63 ? I'm having hard time finding a 4g63 evo block over here, any other mitsu use similar block that can be used instead of the evo's ?
Old Jul 8, 2010 | 09:00 AM
Ev0ikon's Avatar
I replaced my "pulley" with a Fluidmpr unit. Did you use the stock unit?
To the other person that cracked at the same spot, did you also use the stock "crank pulley" ?
Old Jul 9, 2010 | 06:26 PM
rh9's Avatar
rh9
I'm using the stock crank pulley
Old Jul 9, 2010 | 06:27 PM
boostedwrx's Avatar
Crank was dominated!
Old Jul 9, 2010 | 06:32 PM
n2oiroc's Avatar
clutch and flywheel imbalance would be more likely than a damper problem.
Old Jul 9, 2010 | 06:34 PM
VQChris's Avatar
wow
Old Jul 9, 2010 | 08:48 PM
JohnBradley's Avatar
What size bearings are in there? Typically they break on a launch if they are going to do it. Mine is fine...knock on wood....and I do rape on it frequently.
Old Jul 9, 2010 | 09:27 PM
BLKCarbonEVO's Avatar
Holly shize!!! I really hope my motor holds up. I just built it and I don't want to have to baby it in fear of breaking it...
Mikey
Old Jul 9, 2010 | 09:31 PM
SOEuro's Avatar
Originally Posted by smokedmustang
Holy crap!! Forget the crank!! You better get your 2nd toe straightened out first!! LOL. jk, That sucks.
lmfao
Old Jul 9, 2010 | 09:40 PM
Jmelocik@Spec-Ops's Avatar
The only time I saw a break like this was when a guy brought me his motor, trans, still together. I pulled everything apart but found that his Exedy twin hadn't been properly aligned and was therefore out of balance and revved pretty high fairly regularly. The alignment marks (paint strip) on the Exedy has to be re-aligned correctly. His crank broke was almost identical to this one.
Josh
Old Jul 10, 2010 | 12:13 PM
VQChris's Avatar
Old Jul 10, 2010 | 12:27 PM
evo<3's Avatar
yep mine broke almost excatly the same, and i was told it could of been due to the clutch/fly that prolbaly wasnt aligned correctly.. owell gave me a reason to build my motor
Old Jul 11, 2010 | 11:48 AM
evosdad's Avatar
This is pretty common among 2.4 cranks in both the 6bolt dsm and the 7bolt evo world. I personally believe it's probably caused due to the additional torque the engines produce.
