Making less boost in the winter??
Old Nov 19, 2003 | 10:28 PM
mitsuorder's Avatar
been getting some irradic boost spikes lately
Old Nov 19, 2003 | 11:39 PM
bpclements's Avatar
I know on my car with the stock controller on I am only reading around 17.5 psi. I can get to 19psi on colder days. I believe the wastegate is controlled by a duty cylce that is in the ECU. I am not sure if it alters this cycle or keeps it always at the same percent per rpm. If the last is the case then there will be variances in the boost because each cars ECU is not tuned to that specific car. When I had my Joe-P in and set for 19psi I would not see any spikes. The highest psi I would see would be 20psi with the engine loaded down like in 5th at lower speeds. I don't think that anyones piping is loose because that would definitely be noticealbe by lots of spiking and never a constant pressure.
This is just my theory though.
Old Nov 20, 2003 | 09:33 AM
evil8's Avatar
I don't think the ECU knows what boost you are running. If it did it would be able to regulate it and there would not be such variance in boost on different cars.
Old Nov 20, 2003 | 10:54 AM
JT-KGY's Avatar
Doesn't ECU reprogram like dynoflash give you more boost?
Old Nov 20, 2003 | 04:01 PM
evil8's Avatar
From what I read dynoflash does not increase peak boost, it holds peak boost longer.
M3EvoBR
Aug 7, 2008 06:39 AM
IHUNTV8
244
Jul 17, 2008 10:08 AM
thatsMR2u
Jul 27, 2006 01:28 PM
19psi
May 27, 2006 08:49 AM
JT-KGY
Jan 20, 2004 11:45 PM
