1/4 mile Peak Boost Through Gears
Old Jul 27, 2006 | 01:18 PM
thatsMR2u's Avatar
I street set my boost to hit 28psi with my MBC in 3rd gear and make full boost on the street around 4000 rpms- well with the MR 6 speed I enter in the next gear between 5100-5400 rpms by shifting at around 7400 but my datalogger only reads that im making about 24.5 psi in each gear but holding till 23 to redline- Dont forget im running stock like turbo (IX 20g)- should i be hitting higher boost in the gears or am i shifting into its inefficiency range-- others that run meth or race gas please share experiances
Old Jul 27, 2006 | 01:21 PM
Warrtalon's Avatar
Think about it. YOu hit peak boost at 4000rpm, but by 5500rpm, which is where you enter the next gear, you've already seen 1500rpm worth of taper. You'll never see as much peak boost running down the 1/4 as you will in a low rpm roll-on to boost, because it spikes and is at its highest point.
I see 26.5psi peak on the MAP sensor when dyno'ing in 3rd or when doing 3rd gear pulls on the road, but on the drag strip, I don't even see 25 in 4th...
Old Jul 27, 2006 | 01:28 PM
thatsMR2u's Avatar
ok thanks thats what i figured- i just wanted to make sure my wastegate buckle wasnt overtightend causing boost spike just on a roll on
EvoJoeIX
Apr 25, 2010 02:15 PM
bvdawg13
13
Apr 19, 2007 11:07 AM
an0ther
Nov 29, 2005 09:02 AM
evolutionist
Sep 20, 2003 05:01 AM
evilution8
Sep 1, 2003 12:41 PM
