Acree's MAP 2.4L FP Black Build
Old Jul 6, 2010 | 09:41 AM
06MREvo's Avatar
Nice build man...good luck & keep us udpated...I'm looking forward to the results....haha man...I wish I could complain about E85 1.5 miles in the wrong direction from work...sh*t...haha...
Old Jul 6, 2010 | 09:54 AM
38six's Avatar
Originally Posted by Remy
E85 is a mile and ahalf away and you are not sure about using it? Most of us would kill for that distance lol. Use the e85 and stop playing around
Good luck with the build.
+ 1, put a map switch in for 93 pump just in case your unable to get to the station that is only a 1.5 mile from your house.
Old Jul 6, 2010 | 11:16 AM
scheides's Avatar
EvoM Moderator
Originally Posted by Acree
I honestly don't know how the meth kit is currently wired. It was installed by the shop the previous owner used. I will have to look into it after the major build is finished. I want to get everything running, then I will be converting to ECU-Controlled boost and SD. That's all Phase II.
-Acree
Nice Just in case you haven't seen it:
https://www.evolutionm.net/forums/wa...ther-last.html
Mapswitching is da bomb!
Old Jul 6, 2010 | 11:25 AM
Acree's Avatar
Yes sir, that is precisely what I will be doing. The one exception is the gauge layout. I am a fan of maintaing stock appearance. Therefore, I will be incorporating the meth injection status leds into the stock tachometer gauge face with a custom face layout and everything. It should be a bad @ss setup. That will have to wait until after the engine build is complete.
-Acree
Old Jul 6, 2010 | 12:13 PM
Svendiesel's Avatar
Sweeeeeet, another one for the 2.4/FP Black Army Im doing 93+meth for mine
You doin standard rod or long rod??
Old Jul 6, 2010 | 12:17 PM
victoryred's Avatar
Seems like everybody is doing fpblack builds. I guess the little stock appearing turbos saves a lot of money to a 35r kit
Old Jul 6, 2010 | 12:20 PM
Acree's Avatar
I was originally going to do a LR build, but MAP has their drag car revving to 9k rpm all day long. That's good enough for me. I'm going to be setting my limiter around 8300-8500 rpm depending on where the black falls.
It's important for me because when I pop my hood, I want it to look completely stock. I will be utilizing the stock heat shields as well. I want the build to maintain a very stock feel.
-Acree
Old Jul 6, 2010 | 01:59 PM
Svendiesel's Avatar
Yea the black wont need to rev too high, thats where I figure my rev limiter will be around too but I did the long rod version. Im putting the shield on as well just so everything looks relatively unassuming. I hated how the shield looked, so I took a drill and an abrasive pad and stripped all the rust and crappy finish off, washed it, and then hit it with some BBQ Paint, and it looks **** now I even painted the screws and washers that hold it onto the manifold because they looked like crap too.
Old Jul 6, 2010 | 02:06 PM
Acree's Avatar
Hah interesting. I might have to do that. It looks good.
-Acree
Old Jul 6, 2010 | 07:18 PM
BLKCarbonEVO's Avatar
Good luck on your build Acree. I would honestly look into the New GSC cams. They are amazing and the M2s are nothing special. std S2s gain 25hp over them and these custom GSC cams gain 30-40 over the std S2s. Here is my thread on the new cams if you have not seen it yet. https://www.evolutionm.net/forums/ev...stom-cams.html
Good luck and if you have any questions let me know, btw 10.5:1 Static is a bit high for pump 93 however it really depends on your dynamic compression and 10.5:1 is doable if you have large cams and a thicker PE head gasket.
Mikey
Old Jul 6, 2010 | 09:16 PM
Acree's Avatar
Trust me, I've been following the thread. I PM'd Aaron the same day the thread was posted. I'd like to get these cams in this build. I just need ER to come out with a definite "Yes we have them. Pay us."
-Acree
Old Jul 7, 2010 | 02:55 AM
still*boostn's Avatar
thats funny. i blew my stock turbo 9 on 28psi(spiking 33 on launch, when i blew it). rod out that front, piston out the back on #3.
then i went with an AWD 2.4L
cheers for another 2.4L build!
Old Jul 7, 2010 | 06:32 AM
RockmanX's Avatar
nice a couple 2.4 builds going on. good to see stuff like this for sure more for the fp black 2.4 army.
save 2k -3k and produce extremely close to the same power levels as a 35r turbo. i still dont see the point in going higher then the fp black unless your shooting for 750+ then understandable.
Old Jul 7, 2010 | 09:22 AM
Svendiesel's Avatar
Second that, FP Black is basically the last turbo 95+% of this community could ever need.
Old Jul 7, 2010 | 11:10 AM
Acree's Avatar
Now let's just hope they can meet the "2 week" return timeline they claim.
-Acree
