Ets licp~
Old Jul 14, 2010 | 07:35 PM
VRSF Tiago's Avatar
Yeah if that's normal by design that's not a very good design...
Old Jul 14, 2010 | 07:39 PM
TommiM's Avatar
No thats not normal by design. I have an ets licp w/ stock intercooler and I was able to put my stock undertray back on with no trimming or issues whatsoever. Part of the problem I see in the first pic is that the t-bolt clamp is upside down. I would flip that a bit so the scew doesnt poke at that downward angle so much.
Old Jul 14, 2010 | 09:17 PM
Ryuartz's Avatar
Thanks a lot for info. I will definately reinstall LICP and flip the t-bolt clamp.
Old Jul 14, 2010 | 10:05 PM
S14Swap240sx's Avatar
loosen the couplers a bit, move it upward and tighten em again. mine sat low at first but just a quick adjustment fixed it all up. im running the stock undertray and im having no problem!
Old Jul 15, 2010 | 08:05 AM
ETS Michael's Avatar
You should be able to install the under tray back on the vehicle. You might have to loosen the clamps up and adjust the pipe around to get it to fit properly.
Thanks!
Michael
Old Jul 15, 2010 | 02:12 PM
Ryuartz's Avatar
Thanks!
Michael
Yes Sir~ Thanks a lot.
Old Jul 15, 2010 | 02:48 PM
Thanks!
Michael
exactly. I was so happy with all my ets parts fitment. Its soo nice when things fit like oem.
Old Jul 15, 2010 | 07:26 PM
Ryuartz's Avatar
Update : I just reinstalled a ETS LICP. I moved around both couplers, mainly adjusted the coupler that connects to the turbo's j-pipe. I was able to push up more and now, it sits much higher than it used to be. I put the undertray back on with np but it looks like undertray holds and supports the licp from bottom cuz ets licp still sits lower than stock one. But it's all good. The only drawback is that the LICP is touching the A/C rubberish hose so I wrapped the hose with lots of electric tape to prevent any tears. Thanks to all of you with the info and help, especially evo unknown & Heavens Turbo who gave me the step by step instructions. I really appreciate it.
Old Jul 15, 2010 | 07:50 PM
VRSF Tiago's Avatar
Yeah no need for the electrical tape, that hose is fine.
Old Jul 15, 2010 | 07:56 PM
Ryuartz's Avatar
oh ok. i did it just in case. haha. Used tape as sort of cusion. Thanks anyways.
Old Jul 16, 2010 | 08:47 AM
Sweet!!
Old Jul 16, 2010 | 01:48 PM
heavens turbo's Avatar
no problem ryuartz. i wish i was more computer saavy, so i could have got you those pics. i still gotta wrap my a/c hose too. after 4 months, there is a little wear, but not bad. goin to parts store today to find something!
Old Jul 16, 2010 | 02:38 PM
boostedwrx's Avatar
It shouldnt be hanging that low - you need to twist the coupler that is attached to the intercooler inlet more towards the rear of the car and it will level the intercooler pipe out. You should be able to fit the stock undertray on just fine.
Old Jul 16, 2010 | 07:31 PM
TommiM's Avatar
^^+1. Loosen up all the clamps and tweak the pipe around. If it is still that low that just means that the whole system is slightly off which may cause a coupler to blow off during high boost. Once its on straight it will fit just right and no worries about blowing off under boost. ETS licp is top quality stuff.
Old Jul 16, 2010 | 10:35 PM
Ryuartz's Avatar
yea. I was able to put undertray back on after few tweaks. Thanks a lot guys. I agree that ETS products =
