Ets licp~
Old Jul 13, 2010 | 02:45 PM
Ryuartz's Avatar
Ets licp~
I don't know if anybody have this problem. Recently, I installed ETS lower intercooler pipe and somehow it sits really low . Therefore, unable to put back the undertray. Is it because I am running stock FMIC? I checked couplers and it seems ok on both sides. Any helps would be appreciate. Here is pix.
Old Jul 13, 2010 | 02:48 PM
erald01's Avatar
its normal
Old Jul 13, 2010 | 02:49 PM
OneCrzyEvo21's Avatar
Same exact thing on mine bro, im not on stock fmic or stock turbo though, so i dunno if that would affect anything..mine sits very low like that also. I think its just the design, nothing bad just dont go nose first into drive ways...
Old Jul 13, 2010 | 02:51 PM
Ryuartz's Avatar
THanks guys. That was fast. . So, NO MORE UNDERTRAY?
RoMeIX's Avatar
Mine sits like that as well, I am on stock intercooler. I just left that part of the undertray off.
Old Jul 13, 2010 | 02:54 PM
dabizkit's Avatar
good post. im looking to get that licp too but now i dont know =( im lowered already. are you dropped ryuartz?
Old Jul 13, 2010 | 02:56 PM
I wouldnt run the understray, especially if ur going to want to run open dump in the future
Old Jul 13, 2010 | 02:59 PM
Ryuartz's Avatar
No drop yet. There isn't extra mounting part like stock one. so it just hanging like that. but performance wise .
Old Jul 13, 2010 | 03:03 PM
RoMeIX's Avatar
Ive had mine for over two years now with no issues. Also definitely noticed quicker spool up after install and tune.
Old Jul 13, 2010 | 04:18 PM
thedru13's Avatar
I was able to adjust mine a bit. Doesn't hang as low. Still hangs lower than stock one but I was able to rotate it up a bit.
Old Jul 13, 2010 | 06:03 PM
heavens turbo's Avatar
you didn't push it up enough. i have it with the stock intercooler. no sagging, undertray on with no rubbing. solid.
Old Jul 13, 2010 | 06:14 PM
Ryuartz's Avatar
Cool. Sounds great. so, push up FMIC side? Thanks a lot.
Old Jul 13, 2010 | 06:19 PM
evo unknown's Avatar
I noticed it sits a little lower than the OEM LICP. It is because it does not have a bracket to help support it. However, I was still able to get the undertray on no problem.
Old Jul 13, 2010 | 06:34 PM
well, on install, i positioned the small coupler so it would go pretty far onto the neck by the o2 housing, and i pushed the fat end onto the pipe as far as it would go. when i installed the pipe into the stock coupler, i was able to push it almost until it was touching the fmic inlet. as evo unknown said, it may sit just a little lower than stock, but i swear, mine was not hanging down bad at all. definately no probs with undertray.
Old Jul 14, 2010 | 07:22 PM
and i can't upload pics here. dammit.
