can i drive on ethanol e85/e70 with 1050cc and walbro 255
Well i want to try ethanol e85/e70
i have one walbro 255, 1050cc injectors, fp3065 turbo
do i need bigger injectors or double pumper ?
1450's should be enough for your setup on a double pumper, I'm seeing 94% IDC on 1450's and double pumper. However, I did up my base fuel pressure from 43 to 48psi for a little headroom.
Sorry to steal the thread for a min, do you guy think I'll be fine w my set up for e85 and not max anything. Single walbro, old school fp green,and I'm looking for around 1200 injectors, @ 28psi.
Abuddy of mine made 500+awhp on e-85 on a single modded wally.
Here's a little cheat sheet for E-85 injector sizing. This is assumed you have 43.5 base fuel pressure too:
Originally Posted by DarkHorse
390cc @ 100% IDC will support 21.80 lbs/min. Global Correction: +50.00%
390cc @ 80% IDC will support 17.44 lbs/min
450cc @ 100% IDC will support 25.15 lbs/min. Global Correction: +30.00%
450cc @ 80% IDC will support 20.12 lbs/min
550cc @ 100% IDC will support 30.74 lbs/min. Global Correction: +6.36%
550cc @ 80% IDC will support 24.59 lbs/min
580cc @ 100% IDC will support 32.42 lbs/min. Global Correction: +0.86%
580cc @ 80% IDC will support 25.94 lbs/min
650cc @ 100% IDC will support 36.33 lbs/min. Global Correction: -10.00%
650cc @ 80% IDC will support 29.07 lbs/min
660cc @ 100% IDC will support 36.89 lbs/min. Global Correction: -11.36%
660cc @ 80% IDC will support 29.51 lbs/min
680cc @ 100% IDC will support 38.01 lbs/min. Global Correction: -13.97%
680cc @ 80% IDC will support 30.41 lbs/min
720cc @ 100% IDC will support 40.24 lbs/min. Global Correction: -18.75%
720cc @ 80% IDC will support 32.20 lbs/min
750cc @ 100% IDC will support 41.92 lbs/min. Global Correction: -22.00%
750cc @ 80% IDC will support 33.54 lbs/min
780cc @ 100% IDC will support 43.60 lbs/min. Global Correction: -25.00%
780cc @ 80% IDC will support 34.88 lbs/min
850cc @ 100% IDC will support 47.51 lbs/min. Global Correction: -31.18%
850cc @ 80% IDC will support 38.01 lbs/min
880cc @ 100% IDC will support 49.19 lbs/min. Global Correction: -33.52%
880cc @ 80% IDC will support 39.35 lbs/min
950cc @ 100% IDC will support 53.10 lbs/min. Global Correction: -38..42%
950cc @ 80% IDC will support 42.48 lbs/min
1000cc @ 100% IDC will support 55.89 lbs/min. Global Correction: -41.50%
1000cc @ 80% IDC will support 44.72 lbs/min
1150cc @ 100% IDC will support 64.28 lbs/min. Global Correction: -49.13%
1150cc @ 80% IDC will support 51.42 lbs/min
1200cc @ 100% IDC will support 67.07 lbs/min. Global Correction: -51.25%
1200cc @ 80% IDC will support 53.66 lbs/min
1600cc @ 100% IDC will support 89.43 lbs/min. Global Correction: -63.44%
1600cc @ 80% IDC will support 71.55 lbs/min
1850cc @ 100% IDC will support 103.41 lbs/min. Global Correction: -68.38%
1850cc @ 80% IDC will support 82.72 lbs/min"
