should i use obx manifold for a red?
Old Jul 15, 2010 | 09:14 PM
Hendrixmx's Avatar
the full race manifold is definitely a quality manifold but imo the cost outweight the gains like I said unless you're making big power like 500+, then it's most definitley worth investing in.
Old Jul 15, 2010 | 09:19 PM
RSMike's Avatar
Originally Posted by ScorpionT
http://www.full-race.com/catalog_ima...vo_PS_Dyno.jpg
+29whp on a stock turbo with 272 cams. Thats impressive no matter how you look at it. The original 345whp is nothing significant, definitely doesnt take much. If the OP is running a Red he will see even better power increases with a good tubular.
For what most will pay for good porting/coating, the tubular manifolds are not a bad buy.
isn't that a 29whp gain from manifold AND cams?
not from a stock engine with cams on it already
Old Jul 16, 2010 | 12:11 PM
ScorpionT's Avatar
Thats possible also, I should call and ask. But, I have seen good gains from just the manifold.
I do agree that for lower HP builds, sticking with the stock (ported or not) isnt a bad idea.
Old Jul 16, 2010 | 01:18 PM
smithrcing17's Avatar
thanks for all the help guys, i think im either going to sell this and get my manifold ported or save up and buy a mona lisa. they look bad ***
Old Jul 16, 2010 | 01:25 PM
RockmanX's Avatar
good call
Old Jul 16, 2010 | 01:28 PM
neonglh's Avatar
So many are proponents of ported stockers, although they are good, they simply wont make the power of a good tubular. Ive seen tubulars make 20-30hp over the stock manifold with a stock turbo.
BS. The Megan manifold, or the OBX will NOT make as much power as a ported stocker. If that were the case, all of the record lists would be using them, and NO ONE is.
SmurfZilla's Avatar
Originally Posted by tvieira24
On a 500+ build I'd go with a quality tubular all day.
So basically an FP Red or Black. He has a red so then you are agreeing that getting a tubular manifold is worth it. LOL.
Just making sure.
Old Jul 16, 2010 | 01:54 PM
VRSF Tiago's Avatar
They don't last long enough to make the list lol.
Anyone who's ever pushed their turbos to the limit for 3-5 minutes straight will understand the value a quality thick walled manifold.
Old Jul 16, 2010 | 02:22 PM
are they like those crazy pics you see taken at night time that glow bright orange?
Old Jul 16, 2010 | 02:42 PM
ETS Michael's Avatar
When looking at a cheap manifold beware of slag inside. Cheap manifolds have a tendency to have a bit of drop through do the lack of QC. The slag will also break off and take out the turbo
Michael
Old Jul 16, 2010 | 03:03 PM
EvoLutionized8's Avatar
I cant believe this conversation is actually taking place.. Seriously, a cheap mani is exactly that cheap. Your gains will not mean diack when it only lasts for a couple months (being optomistic), or worse a new turbo. If you are looking at the <400 range then go with a stocker ported. If you want to get every bit out of that stock appearing turbo, then get a QUALITY tubular. I hear ETS makes some pretty nice stock turbo tubular mani's... I like em a little bit too..
Old Jul 16, 2010 | 03:30 PM
ScorpionT's Avatar
OBX and Megan wouldnt be on my list of good tubular manifolds. My comments were simply comparing good tubulars and a ported stock manifold.
Old Jul 16, 2010 | 03:40 PM
sho669's Avatar
my dad owns a machine shop
why don't you just have him port it then it's not rocket science
Old Jul 16, 2010 | 03:47 PM
VRSF Tiago's Avatar
Porting too much can lead to negative effects.
Old Jul 16, 2010 | 04:55 PM
SmurfZilla's Avatar
My car came with a cheap Megan manifold. That **** cracked at a weld that looked like it had been welded a few times over. Went with a regular stocker. Had no issues. Have a Mona Lisa now so once I sort out my motor options that will be used.
